Engineering, Manufacturing, Design Database and Tools - Engineers Edge
Aircraft and Military MS and NAS Part Identification Guide
 Fasteners, Nuts, Fittings
ANSI - Hardware Guide, Screws, Washers, Nuts, Screws, Set Screws, Thread Stress Area, Hex Bolt Identification
Standard ANSI (inch hardware)
Battery Design and Construction Knowledge
Bearing Design and Application
Bearing Types, Application Chart, Representation, Thrust Designation
Civil Engineering Design Knowledge Menu
Corrosion
Galvanic Compatibility, Localized Corrosion, General Corrosion, Stress Corrosion Cracking, more...
Computer Technology Menu
Thin Client, types of memory, hardware, types of cable..
Definition General
Design and Engineering. Calculators
Design - Engineering Productivity General
Assembly Mass Estimate Worksheet, Design Guidelines. Engineering Ethics, Strength of Materials
Design, Engineering and Manufacturing Calculators Menu Beam Deflection and Stress, Springs, Friction, Tolerance Analysis, Section Properties, Conversion and Equivalents, Pressure Vessels, Thread Stress, more...
Electric Motor Application, Design and Installation Menu
 Electric motor torque, Horsepower, Accelerating Torque and Force, Moment of Inertia, Objects in Linear Motion ...
Encyclopedia Menu
Engineering Drawing Formats Menu
Engineering Drawing and Drafting Menu
Title block, Revision history, Drawing borders..
Engineering Specification and Standards, ASME Engineering Standards Specifications, ASTM International Standards Specifications
Engineering Software Downloads, Finite Element Software Public Domain
Engineering and Manufacturing Testing
Environmental Test and Manufacturing Chambers
Filtration Menu
 Air Filter, Electronic Filter Operation, Air filter Types, ...
Finishing and Plating
Nickel, Gold, Chromate, Electropolishing, Passivate, more...
Fluid Flow Fundamentals
Properties of Fluids, Volumetric Flow Rate, Laminar and Turbulent Flow, Bernoulli's Equation, Head (Pressure) loss..
Friction Equations and Calculation
Coefficients of Friction, Shaft and Journal Pivot Friction Equation and Calculator, Conical Pivot Friction Equation and Calculator, more...
Friction and Wear Knowledge Menu
Gear Design and Application
Gear Application, Formula, Pitch Conversion
General Engineering and Design Data
Drill Size Chart, Tap - Drill size Chart, O-rings, Copper wire, Rivet Installation and application, more..
Heat Exchanger - Table of Contents
Application, Radiator, Parallel Flow, Comparison of Heat Exchangers, more...
Heat Transfer - Table of Contents
Heat Transfer Terminology, Conduction, Convection, Radiant, Heat Exchangers, more...
General Design, Fluid Characteristics, Moody Chart, pipe Schedules, Pipe Burst Strength, Pipe Strength, Cylinder Piston Velocity, more...
Industrial, Testing, and Engineering Equipment
Industrial Coating
Powder coating, optical, overview and application, ..
Industry News Feeds
Aerospace, Aviation, CAD, Metals Industry, Graphics, NASA, Software, Plastics, Space, Robotics, Steel Making
Industry Standards
Instrumentation and Control Devices and Systems
Thermocouple construction and operation, resistance Temperature devices, temperature detection circuit, more..
ISO - Metric Hardware (Screws, Nuts, Set Screws)
Metric Fasteners, Screws, Nuts, Set Screws
Lubrication Knowledge Menu
Manufacturing Processes
Casting, Casting Rib Design, Drill Sizes, Hardness Conversion, Knurl Specification, Extrusion Design, Forging Design, more
Materials
Aluminum, Steel Plate, Stainless Steel, AISI Steels, Rockwell Hardness, Vickers Hardness, Graphite, Polyurethane, Gum Rubber, Brass, Copper, more
Mathematics
Properties of Circles, Volumes of Solids, Areas of Plane Figures, Trigonometric Relations & Constants...
Mechanical Components
Grommets, Military Standard Sizes
Mechanics and Machines Calculations - Simple lever and pulley equations.
Mechanical Tolerance Calculators
Fixed Fastener, Fixed Fastener with Projection Zone, Two Mating Features @ MMC, Three Mating Features @ MMC, True Position, Hole / Feature Pattern Plot
Mechanical Tolerance Chart and Guide
Geometric Dimensioning and Tolerancing Resources
Pan Head, Socket Head, Shaft - Hole, Hex Head, Dowel Pin, International Tolerance Chart, ISO Tolerances For Fasteners, more
Mechanical Design and Engineering General
What do Mechanical Designers do?, What do Mechanical Engineers do?
Plastic Injection Molding Design and Manufacturing
 Rapid Prototype, Materials and resolution, Design Guide, Common Polymers ( plastic ) used in products...
Power Transmission and Technology
Diesel Engine Technology, Internal Combustion Engine, Drive Line Design, Engine Equation and Formula, more...
Pump Types, Operation and Classification Menu
Centrifugal pump, Impeller types, Pump components, Pump flow classification, more..
Quality and Inspection Process Knowledge
Nondestructive Inspection Guide, Visual inspection, Eddy Current, Magnetic Particle, Penetrant, Radiography, Ultrasonic, 3D Laser Scanning, Metrology, CMM Inspection, more...
Rapid Prototype Menu
Stereolithography, SLA, File Conversion, Design for Tips, Resolution...
Reverse Engineering Knowledge
Reverse Engineering Overview, Reverse Engineering Parts and Components
Section Properties Common Structural Shapes
Section Calculation of moment of Inertia of Square, Square Tube, Rectangle, Round Tube, Round Tube at Center, Hexagon, Triangle, more...
Sheet Metal Manufacturing and Design
Distance Bend to Mold Line, Bend Allowance, Sheet Metal Definitions Terms, Sheet Metal Calculations, Gauge Charts, more...
Simple Machine Lever Calculation
Unknown Lever force and length calculations
Solder Joint Design, Formula and Materials
Lap Joint, Bevel Joint, Butt Joint, Tube Joint, Solder and Braze Materials and Filler, Soft Alloys, more...
Springs Design, Engineering Knowledge Menu
Spring force calculators, compression, tension, torsion..
Statistics Knowledge Menu
Engineering Reliability Statistical Models
, Normal or Gaussian Distribution and Reliability Engineering
Strength (Mechanics) of Materials
Stress, Strain, Hookes Law, Elongation, Young's Modulus, Stress - Strain Relationship, more ...
Structural Beam Deflection and Stress Formula and Calculation
Structural Beam Calculators for Stress and Deflection
Structural Shapes
W Flange, S Shapes, Angle
Thermodynamics
Thermodynamics Definitions General
Properties, Temperature and Pressure, Heat, Work, Energy, Systems and Processes, Change of Phase...
Thread Stress Area and Torque
Thread Stress Area, Threaded Hole Fastener Pullout Stress, Torque Clamp Force Calculator..
Trigonometry Calculations of Complex Triangles
Multiple case calculations for solving triangle lengths and angles
Weld Joint Design and Engineering Formula
Definitions, Drawing Symbols, Butt Joint, Shear Load, Normal Load, Torque Load...
Spring Design and Engineering
Spring Terminology, Calculators and Equations, Torsion Spring, Properties and Materials, more...
Pressure Vessel Design and Engineering
Thickness of  Circumferential Shells Under Internal Pressure..
Vee and Flat Belt Design and Data
V Belt Conventional Sizes, Application, Belt Groove (Sheave) Sizes, Torque and Power, Service Factors, Tension
Volume of  Solids Equation Menu
Cylinder, Hollow Sphere, Spherical Wedge, Cone, more..
© Copyright 2000 - 2008, by Engineers Edge, All rights reserved.  Disclaimer  .
Products and Services
CAD Forum
Engineering Design Data
Engineering Drafting Store
Newsletter Register
Advertise
Feedback
Bibliography
On-Line Games
