Fundamentals of Surveying Theory and Samples Exercises |
Surveying has to do with the determination of the relative spatial location of points on or near the surface of the earth. It is the art of measuring horizontal and vertical distances between objects, of measuring angles between lines, of determining the direction of lines, and of establishing points by predetermined angular and linear measurements. |
Wind Loads on Fences and Hoarding's |
Related model and Full-scale Studies, Wind tunnel studies Full-scale test on fences, Experimental Setup, Results Area averages panel pressures on fences ... |
Asphalt Concrete Recycling |
Asphalt and Concrete Pavement Recycling. publication contains guidance for preparing plans and specifications and for ensuring the quality of recycled bituminous concrete. |
Activated Sludge Wastewater Treatment Plants |
In a conventional (plug-flow) activated sludge plant, the primary-treated wastewater and acclimated micro-organisms (activated sludge or biomass) are aerated in a basin or tank. |
Foundation Design for Building and Structures |
The principles of good foundation preparation are simple, but enforcing the provisions of the specifications concerning the work is more difficult. Inspection personnel must recognize the importance of this phase of the work since, if not properly controlled, problems can result. |
