Torsional Rigidity of Cantilever Wings |
During recent years several very thorough and interesting treatises have been devoted to the investigation of systems of spas and ribs stress, especially for the static's of cantilever wings. |
Spons Dictionary of Engineering |
This is an archive copy from the Smithsonian dates, Jul. 23 1958 and is of content for Civil and Mechanical Engineering. Original publish Publication date 1869. |
Hydraulic Scissor Lift Design Project |
This project describes the design calculation of a Hydraulic Scissor Lift. Usually, a scissor lift is used to lift a certain object to a certain height example- for lifting a car to change a tire. |
Analysis of Large-Sized O-Rings |
A proper criterion to guide how to determine the cross-section diameter of non-standard large-sized O-rings used in deep-ocean pressure chambers (DOPCs) is absent. |
Washers Controlling Loosening of Full Threaded Bolted Joints |
Washers Controlling loosening of Full Threaded Bolted Joints - Bolted joints are used for fastening components together in the industry, aeronautics and in railways. These joints may get loose with time and if not attended timely may result in catastrophic failure also. |
Numerical Analysis Hybrid Spur Gears |
Hybrid gears are composed of high-strength steel, carbon fiber reinforced plastic (CFRP), and adhesive bond to join these materials. In this study, the effect of rack tip radius (TR), drive side pressure angle (DSPA), and rim thickness (RT) on the stress of hybrid gears is investigated numerically. |
Thread Fastener Design and Analysis |
Engineering Fundamentals of the Tightening Process The process of tightening threaded fastener assemblies, especially for critical bolted joints, involves controlling both input torque and angle of turn to achieve the desired result of proper preload of the bolted assembly. |
