Handbook for Machine Designers and Draftsman - Premium Membership Required
Handbook for Machine Designers and Draftsman: Practical engineering design reference handbook.
Open Section 1: Handbook for Machine Designers and Draftsman
  • Mechanical Principles of Design
  • Plain or Sliding Bearings
  • Ball and Roller Bearings
  • Belts and Pulleys
  • Fly Wheels
  • Cone Pulleys and Back Gears
Open Section 2: Handbook for Machine Designers and Draftsman
  • Spur Gears
  • Bevel Gears
  • Friction Gears
  • Worm Gears
  • Helical (Commonly Miscalled Spiral) Gears
  • Planetary (Epicyclical) Gears
  • Ropes
  • Chains
  • Brakes
  • Friction Clutches
  • Cams Design
  • Spring Design
Open Section 3: Handbook for Machine Designers and Draftsman
  • Bolts, Nuts and Screws
  • Wire and Sheet Metal Gages
  • Hydraulics and Hydraulic Machinery
  • Pipe and Pie Joints
  • Minor Machine Parts
  • Press and Running Parts
  • Press and Running Fits
  • Balancing Machine Parts
  • Miscellaneous Mechanism, Construction of Tools and Data
Section 4: Handbook for Machine Designers and Draftsman
  • Performance and Power Requirements of Tools
  • Cast Iron
  • Steel
  • Alloys
  • Steam Boilers
  • The Steam Engine
Section 5: Handbook for Machine Designers and Draftsman
  • The Gas Engine
  • Compressed Air
  • Mechanics
  • Strength of Machine Parts
  • Weights and MEasures
  • Mathematical Tables
  • Index
Contribute Article
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
