How to use images within the author board.
First, select the "Image Icon":
Next select the File/Image Manager Icon:
With the Upload/File Manager open, you have the following general capability Icons.
It is recommended that you create a Folder on EE for your specific images. Images maximum size is 100,000 Kb.
After "Browse" for the desired image, you do need to "upload", then select OK and then "Insert" |
