I have some pdf files that need to convert to editable dwg files. Anyone could give me some advices.
Thanks.
Printable View
Thanks.
Hi Donald,
Later versions of CorelDraw will convert PDF to DXF which is AutoDesk's file-exchange version of DWG drawings.
Dave
Generally, I will not give you the answer to your question, but I **will** guide you into discovering how to solve this yourself.
I have worked with PDF to DWG converter and this program works well. find it in google.
regards,
[QUOTE=Dominguez Mexico;340]I have worked with PDF to DWG converter and this program works well. find it in google.
regards,[/QUOTE]
is that software for free download?
My advise would probably be very amateur but then the easiest way i could think of.
Google yourself a converter, its that easy!:) i google my file converters all the time and they work perfectly. Its actually convenient cause you wont have to install a software and all, you can convert it straight up so its really simple.
I suggest though that if you are to convert numerous files then you really have to download and install a software
convert pdf to dxf? it's surprising to me.
Why? They are both Vector based.
Donald I can help you with that.
