Bolting Calculations in thermal cycling application
I have an assembly with 4 bolts secured with nuts. The assembly is two aluminum pieces held together and an o-ring in between. The assembly has heaters inside of it which means the joints will be subject to thermal cycling. I'm looking to do some calculations to determine what size bolt I should use, how to factor in the thermal cycling, and recommending torque value.
So far I have found one formula that determines torque req. based on the size of the bolt and clamping force required.
The concern is the clamping force being diminished after cycling. Some ideas I've had so far is also employing lock washers and high temp loctite.
Phil
