Basic Tolerance Question.
Sorry in advance for this basic question but I'm confused.
So for a Class IV transitional fit the tolerance on a 1'' hole and shaft is as follows according to this link([URL]http://www.engineersedge.com/class_iv.htm[/URL])
Basic diameter = 1'' Clearance 0.0002''-0.0018''
Hole Dia = 1'' to 1.0009'' difference =0.0009''
Hole Dia =1''+.0009''/-0.0000''
Shaft Dia= 0.9991''-0.9998'' difference =0.0007''
Shaft Dia=0.9991''+0.0007''/-0.0000''
So a machinist has to be more precise on the shaft as there is only .0007'' to play with while the hole has 0.0009'' to play with.
why are the tolerances not done like this below.
Hole Dia = 1'' to 1.0008'' difference =0.0008''
Hole Dia =1''+.0008''/-0.0000''
Shaft Dia= 0.9990''-0.9998'' difference =0.0008''
Shaft Dia=0.9990''+0.0008''/0.0000''
So a machinist has .0008'' to play with on both shaft and hole.
I don't understand why they are allowing greater range of error on the Hole diameter, why isn't the allowable error the same for shaft and hole.
Thanks
Ronan
