Thread: Tolerance interpretation conflict
    Apr 2016
    I have an engineer from one customer who is insistent that the tolerances for any GD&T dimension must be applied to the basic dimension of the print. He is saying that if a basic dimension locates a hole with a true position of .25 mm, the basic dimension is subject to the .25 mm true position tolerance.
    I have a second customer that wants to stack a 2 mm true position tolerance on a 2 mm basic dimension for the hole location.
    Please tell me I am on solid ground that neither modification is acceptable.
    BTW, new member, 1st post.
    2,615
    Quote Originally Posted by Brad54 View Post
    No... though they may be conceptually understanding but not expressing themselves correctly... The basic dimension is considered tolerance-less.. The GD&T tolerance is located and oriented relative to the specified datums about the Basic Dimension specified. The as built hole feature's axis must fall within the oriented and located to the specified datums GD&T position tolerance.
    The basic dimension is NOT variable or moving...
    Stack? can you clarify please...
