Results 1 to 8 of 8
Thread: Old drawing gdt
    Jan 2017
    Old drawing gdt
    I'm updating an old drawing with a note for controlling hole patterns, I want to change to modern GDT. heres what the dwg looks like
    Attached Files Attached Files
    1,814
    Pretty vague drawing... Are the holes all the way through? What are their function?
    Jan 2017
    this is a hopper, it has a hub with a feed screw coming in the left side and a spout on the other side, they want to make sure the two sides are within .060, I want to apply GDT instead of the old school note.
    1,814
    So, your open end request has not been answered and though I know exactly what is required I would like for you to at least attempt to specify the datum structures as well as the related FCF to your design requirements....
    I am ASME Certified Senior GDTP, I train, consult GD&T and DFM/DFMA for a living but I'm not going to do your design for you...
    https://www.asme.org/wwwasmeorg/medi...fication_title
    http://www.engineersedge.com/GDT_Training.htm
    So let's see what you got..
    Jan 2017
    this is what I came up with, it just seams more complicated than the original note.HOPPER GDT R5.PDF
    1,814
    Left Side View - Datums A, B are logical based on the information given.. Locating a BC is illogical in this case. You should locate the 4X orbiting holes back to datum's A and B then declare one or all hole features as datum "C".
    Right side view - Locating the Bolt Circle (BC) is again illogical.. Depending on the thickness (thin) of the Hopper part, I would simply locate all the hole features back to datum's A, B, and C to the tolerance required.
    If the hopper part is thick manufacturing becomes a challenge therefore I would Right Side View declare the outer (or inner) flat surface as datum D, maybe define a parallelism. Then locate the center hole back to Datum's D, B, and C, Then declare that hole datum "E". Then locate the four orbiting holes to datum D, E and C.
    Next time you want a high quality set of Michelin tires for your vehicle - simply tell the tire place "put tires on it" and see what you get...
    Proper Dimensioning and Tolerancing design is often the difference between a functioning, interchangable, manufacture-able part and something else..
    Jan 2017
    ok see if this is going to work
    1,814
    Total runout? not even close . You need training... At least read my book.
    See:
    Geometric Boundaries II, Interpretation and Application of ASME Y14.5-2009 GD&T
    http://www.engineersedge.com/geometr...ies-2-book.htm
    Basic of GD&T training per. ASME Y14.5-2009
    http://www.engineersedge.com/trainin...e-training.htm
