Thread: How far can a round bar be rotated before deformation - formula
    May 2017
    Monmouthshire, UK
    I have been trying to find a formula to work out how far can a round bar be twisted before being deformed.
    I have tried a few from various sources, with great varying results.
    Basically, I trying to find how far I can rotate one end of a round bar in DEGREES before it goes beyond its limits staying deformed.
    The round bar would be 330mm in length, but the diameters of the bars vary from ie: 15mm to 25mm.
    All the bars will be EN24T (4340/817M40).
    Once I know how far a bar can be twisted in DEGREES at one end, I can then design levers to ensure the bar is not overstressed using CAD.
    Can anyone help with a formula as the Torsion value applied at one end of the bar will be unknown.
    thanks
    2,611
    May 2017
    Monmouthshire, UK
    thanks for that.
    But the Torsion/Torque is always unknown.
    If I can find the torsional limit in degrees or radiants of a bar before being deformed. I can then produce a lever of a certain length as I know the amount of travel/arc that will be applied at the end of the lever.
    example: the lever attached to the end of the bar could see travel/arc of 50mm, so a radius for the lever would have to be found as not to over torsion a bar deforming it and allowing it to return to rest. A short lever with the 50mm travel would have far greater torsion/torque than a longer lever with the same 50mm travel.
    If thats of any help of what I am trying to achieve.
    thanks
    2,611
    Get the yield specification/characteristics of your target material under torsion loading..
    Then, determine the torsion to reach that yield strength.
    Apply a FOS and back calculate your angle of twist...
    May 2017
    Monmouthshire, UK
    thanks
