Engineering Design Data: Menu - excel calculators > Design Engineering
Design and engineering related excel spreadsheet calculators
Next Page
Pages: [1] 2
Assembly Analysis Cost and Efficiency Excel Spreadsheet
The first step is to determine the assembly sequence. The assembly time for each component part is then obtained by adding the handling time of that part to its insertion time. Once the components and the assembly time for each are known, total assembly time and assembly cost for the existing design is evaluated.
Heat Transfer Coefficient Calculations
This Worksheet will allow you to calculate heat transfer coefficients (h) for convection situations that involve internal flow in a tube of given cross-section.
Bearing Load Calculator
This design engineering spreadsheet calculates the loads on linear motion bearings. It takes forces applied at the cutting tool and bearing locations (X,Y,Z) as inputs. The X-Y center of the work volume, at the table height, is defined as the origin.
Failure Modes of Simple Pressure Vessels Excel Calculator
Calculate cylinder critical thickness, end cap critical thickness, yield, stress vs depth
Contact Stresses Between Crossed Cylinders Analysis Excel Calculator
Calculate stresses due to contact, loading, applies axial load, etc.
Composite Sandwich Cylinders Analysis Excel Calculator
Method for sandwich cylinders with isotropic core and equal thickness isotropic facings.
Buckling of Foam Core Sandwich Panels Excel Calculator
Shear and compression buckling of a cored sandwich panel with isotropic face sheets.
Buckling of Uncored Composite Panels Excel Calculator
Simple, conservative panel buckling for uncored composite laminate panels.
Laminate Principal Strain Excel Calculator
Derives the principle strains in a laminate element given the laminate properties and the input loads.
Neuber Elastic Stress Correction
Analysis and comparison of various methods for calculating the flexibility of mechanically fastened joints. Neuber Elastic Stress Correction
Next Page
Pages: [1] 2
© Copyright 2000 - 2017, by Engineers Edge, LLC All rights reserved.
Disclaimer
