Engineering Design Data: Menu - excel calculators
Excel engineering calculator downloads and applications
  • Business
  • Civil Engineering
  • Design Engineering
  • Electrical Electronics Excel Calculators
  • Fluids Engineering
  • Heat Transfer Engineering Design
  • HVAC Heating Ventilation Air Conditioning
  • Manufacturing
  • Welding Design and Engineering
  • Prev Page | Next Page
    Pages: 1 [2] 3 4 5 6 7 >>
    Angle Fitting – Niu Method Excel Calculator
    Stress analysis method for a machined angle fitting.
    Bathtub Fitting Niu Method Excel Calculator
    Stress analysis method for machined bathtub fittings.
    Pressure Vessels Stress Method Excel Calculator
    Stress method for thin-shelled pressure vessels under constant pressure.
    Pressure Loaded Flat Isotropic Panel Excel Calculator
    Large and small deflection methods for panels of different shapes.
    Cylindrical Roller Contact Stresses Excel Calculator
    Contact (sub surface) stresses for a cylindrical roller on a flat plate.
    Flange Buckling Coefficients Excel Calculator
    Flange buckling coefficients for isotropic materials.
    Collapse Of Shear Web with Holes
    Collapse Of Shear Web with Holes Excel Calculator
    Pulley Cable Loads Excel Calculator
    Method for deriving the resultant load on a cable pulley and checking the pulley load and the cable load.
    Buckling of Flat Plates Excel Calculator
    Buckling of Flat Plates Excel Calculator for flat, thin isotropic plates.
    Buckling of Curved Plates
    Buckling of Curved Plates: Description: Buckling allowables for curved, thin isotropic plates.
    Disclaimer
