Engineering Design Data: Menu - excel calculators
Excel engineering calculator downloads and applications
  • Business
  • Civil Engineering
  • Design Engineering
  • Electrical Electronics Excel Calculators
  • Manufacturing
  • Prev Page | Next Page
    Pages: 1 2 3 [4] 5 6 7 >>
    Performance Jet Engines Excel Spreadsheet
    Ideal and non-ideal performance of turbojet, turbofan and ramjet engines excel spreadsheet calculator.
    Bernoulli’s Theorem of fluid flow Excel Spreadsheet Calculator
    Bernoulli’s Theorem of fluid flow excel spreadsheet. This calculator examines one simple example of a water system and how fluid flow engineering analysis is done.
    Universal Conversions Calculation Excel Spreadsheet
    In this excel spreadsheet there are conversions for the following: Area, Volume, length, Dry Volume, Mass, power, Energy, Force, Temperature, Velocity, Acceleration, Time, Data
    Waste Storage Design Excel Spreadsheet Calculator
    Waste Storage Design Excel Spreadsheet Calculator. Assists in design of waste storage facilities based on user inputs of animal type and number, bedding used, number of days needed to store manure, feedlot area, etc. Outputs include dimensions of storage pond, cut and fill volumes, percent solids, and linear quantities. Includes a Help tab.
    Underground Outlet Design Computations Excel Spreadsheet Calculator
    Underground Outlet Design Computations Excel Spreadsheet Calculator. Assists in sizing underground tile lines for both pressurized and non-pressurized flow conditions. Allows up to 5 inlets and 5 tile reaches, and will assist in selecting an appropriate surface inlet if one is needed. Used for round conduits only, but can accommodate round and rectangular orifices. Includes a Help tab.
    Roof Gutter Design Simplified Excel Spreadsheet Calculator
    Roof Gutter Design Simplified Excel Spreadsheet Calculator. Simplified version of the Roof Gutter Design spreadsheet. Includes a Help tab.
    Roof Gutter Design Excel Spreadsheet Calculator
    Roof Gutter Design Excel Spreadsheet Calculator. Assists in designing roof gutters, downspouts, and roof gutter underground outlets, and is based on Wisconsin NRCS FOTG Standard 558. Includes a Help tab.
    Rock Chute Excel Spreadsheet Calculator
    Rock Chute Excel Spreadsheet Calculator. Assists in designing rock chutes based on user inputs such as channel geometry, design storm data, and output profile and cross section. Calculates required D50 and quantities. Includes a Help tab.
    Pump Sizing Excel Spreadsheet Calculator
    Pump Sizing Excel Spreadsheet Calculator. Determines pump size depending on user inputs. Inputs require some knowledge and experience with pump sizing.
    Manning's N Applications Trapezoidal and Circular
    Manning's N Applications (Trapezoidal and Circular). Calculates capacity and velocity of trapezoidal or circular flow conduits by using Manning's equation.
    © Copyright 2000 - 2017, by Engineers Edge, LLC All rights reserved.
    Disclaimer
