Engineering Design Data: Menu - excel calculators
Excel engineering calculator downloads and applications
  • Business
  • Civil Engineering
  • Design Engineering
  • Electrical Electronics Excel Calculators
  • Fluids Engineering
  • Heat Transfer Engineering Design
  • HVAC Heating Ventilation Air Conditioning
  • Manufacturing
  • Welding Design and Engineering
  • Prev Page | Next Page
    Pages: << 6 7 8 [9] 10
    Building Wind Loading Analysis Wall Components and Cladding
    Building Wind Loading Analysis Wall Components and Cladding Excel Calculator. Program Assumptions and Limitations: 1. This program assumes only enclosed or partially enclosed buildings. Open buildings are NOT considered. 2. Worksheet for Simplified analysis is applicable for low-rise buildings meeting the criteria of Section 6.4.1. 3. In the worksheet for Simplified analysis, the design MWFRS wind load is calculated for each direction. The design MWFRS load is assumed to be the total wind load on either the width or the length of the building respectively.
    Snow Load Analysis Calculator per ASCE798S
    This program is a workbook consisting of three (3) worksheets, described as follows: Worksheet Name Description Doc This documentation sheet Snow Load Snow loading analysis for buildings with flat or low slope roofs Snow Map Ground snow loads map (Figure 7-1 of ASCE 7-98 Code)
    Wind Load Low Rise Buildings per. ASCE 7-87 Excel Calculator
    Spreadsheet program written in MS-Excel for the purpose of wind loading analysis for buildings and structures per the ASCE 7-98 Code. Specifically, wind pressure coefficients and related and required parameters are selected or calculated in order to compute the net design wind pressures.
    Structural Wind Loading Analysis Simplified for Low Rise Buildings
    Structural Rectangular Spread Footings Table Format
    Download: Structural Rectangular Spread Footings Table Format. Structural Rectangular Spread Footings Table Format Calculator
    Snow Load Analysis Program per ASCE702S
    Roof Snow Load Analysis Program "ASCE702S" is a spreadsheet program written in MS-Excel for the purpose of flat roof snow loading analysis for buildings and structures per the ASCE 7-02 Code. Specifically, coefficients and related and required parameters are selected or calculated in order to compute the net design snow loads, including snow drift due on lower roofs and rain-on-snow surcharge.
    Axially Loaded Pile Analysis Calculator Excel
    Terzaghi's One-Dimensional Consolidation Theory Closed-Form Solution
    Terzaghi's One-Dimensional Consolidation Theory Closed-Form Solution.
    FRAME PORTAL AND GABLE RIGID PLANE FRAME ANALYSIS
    "FRAME" is a spreadsheet program written in MS-Excel for the purpose of plane frame analysis of portal and gable rigid plane frames subjected to various types of loading.
    Precast Pre-Tensioned Beam Design Calculator Excel
    This excel spreadsheet calculator includes three sheets for pre-tensioned beams.
    Disclaimer
