Engineering & Drafting Store | Engineering Forum | CAD Forum | Engineering Downloads | Engineering GD&T Training
Engineering Data Directory | Engineering Links | RSS RSS | Contact | About | Newsletter | Advertise
Welcome to the Engineer's Edge, we are committed to being your Total Solutions design, engineering and manufacturing resource
What's New at Engineers Store? more
Engineering Paper - Forms
$2.99
Featured Advertisers
Carpenter Technologies
Specialty metal supplier, stainless steels, aerospace metals, tool and die sets, bearing steels, and more...
USBFireWire.com
Custom and standard engineered Firewire, Serial ATA, and USB Cables and adapters.
PipeFlow.co.uk
Engineering fluids flow software for analysis and design.
News
Read all about it!
Download Engineers Edge Toolbar - Take the power of Engineers Edge with you anywhere!
What's New at Engineers Edge!
Engineering News related links
  • Structural Steel Angle Properties - Structural Steel Angle Section Properties for BSI BS EN 10056-1      -
  • New Material Could Lead More Efficient Fuel Cells - Engineers Edge - A new material characterized at the Department of Energy's Oak Ridge National Laboratory could open a pathway toward more efficient fuel cells.     -
  • Strain Gage Transducer Configurations & Review - Strain gage elements are available in a wide variety of configurations in both wire and foil gages. Strain gages can take many forms for transducer or stress analysis applications. Strain gages are constructed with many loops of wire material typically made from Constantanl. Constantan resistance     -
  • Researchers Create Hydrogen with Help of Solar Energy and Water - Engineers Edge - Penn State researchers are developing a low cost process to produce fuel hydrogen help of water, solar energy and Nanotube diodes.      -
  • Portable Magnetic Resonance Imaging MRI Machines - Engineers Edge - Magnetic resonance imaging or (MRI) is typically used within the medical industry to visualize the internal structure and functions of the human body. MRI technology provides     -
  • Finite Element Analysis FEA Review - Finite Element Analysis (FEA) is a powerful tool that essentially divides a complex structure up into many small elements, where for each the stresses and deformations can be solved for using known equations of elasticity. Because the boundaries of each element in contact with another      -
  • Innovative Pipe Inspection Robot That Can Climb! - Engineers Edge - Industrial pipe systems can be complex, narrow, and generally inaccessible. Pipe installations can have vertical, horizontal, and oblique junctions. Critical pipe installations must be inspected for leakage areas, obstructions, valve failures and more. Moreover, industrial pipe systems require periodic cleaning      -
  • Innovative Future for Electronics Components made from Plastics - Engineers Edge - Physics World July edition features an interesting review by three Israeli researchers, Marianna Khorzov and David Andelman, from the School of Physics and...     -
  • Electronics Chip-Cooling Technology Achieves 1,000-watt Capacity - Engineers Edge - Researchers at Purdue University have developed a technology that uses "microjets" to deposit liquid into tiny channels and remove five times more heat than other experimental high-performance chip-cooling methods for computers and electronics.      -
  • Major Steps Made in Developing Printable Optical Electronics & LCD’s - Engineers Edge - Major Steps made in Developing Printable Optical Electronics & LCD that can be used for creating radio frequency identification tags and flexible watch displays.      -
  • Innovative Robotic Grippers - Shape Memory Materials - Engineers Edge - A team led by Victor Etxebarria at the Department of Electricity and Electronics at the University of the Basque (UPV-EHU) is studying the characteristics of various memory forming materials for use within the next generation of robotic grippers...     -
  • Reverse Engineering Method Using Advanced 3D Laser Scanner - Engineers Edge - For most applications, engineering and design is executed out conceptually, the concepts are flow charted,      -
admin
About Us | Advertise With Us | Site Map | Contact | Feed Back | Privacy Policy
Copyright © 2000 - 2008 www.engineersedge.com. All rights reserved.
