Random Links
Static Mixer Review
Materials Chemicals Adhesives Menu
Static Mixer Suppliers
Static mixers are used within industry to mix chemical aggregates. These devices are normally cylindrical shaped and contain channels, fins or other static features to combine and mix selected chemicals. Static mixers maybe used with all fluid or chemical viscosity mediums.
Static mixers are selected and used based on fluid viscosity, number of fluids, chemical compatibility, and the degree to which the materials need to be mixed. Common application of static mixers is for mixing two or more chemicals which will react into a adhesive, epoxy, or other processing chemical for industrial use.
Static mixers are readily available in all configurations and applications throughout industry.
Internal Mixing Elements
Contribute Article
Disclaimer
Engineering Store
Engineering Training PDH
Products & Services
Engineering Design Data
Industrial News Buzz
Newsletter Register
Feedback
GD&T Training ASME Y14.5-2009
DFM Training
Contribute Article
Share |
