Engineers Edge
Random Links
Hydraulic & Pneumatic Torque Wrenches Application Review
Torque Design Menu
Pneumatic Torque Wrenches | Hydraulic Torque Wrenches
Hydraulic & Pneumatic Torque Wrenches are industrial torque tools used to install or remove fastener in applications requiring high torque or production performance. In most heavy industrial fastener applications, the requirement for applied high torque to nuts and bolts are due to:
  • Fatigue loading or installation requirements.
  • Removing challenging fasteners that have been torqued to high loads or have been exposed to corrosion or heavy loading conditions resulting in galling.
Technicians sometimes use breaker bars with extended length "cheater pipes" attached to remove or torque fasteners in these challenging situations. However, all industrial tools and technicians have their operating limits and can break or injure. In these “controlled torque” or "power torque" applications, industrial Hydraulic & Pneumatic Torque Wrenches are the logical solution. Other wise, technicians will likely strip threads, break bolt heads or even cause personal injury.
Hydraulic & Pneumatic Torque Wrenches are available in a variety of sizes, torque capabilities and custom applications for applying torque to virtually any type of fastener. Hydraulic & Pneumatic wrenches can be bulky and and laborious to operate. however, the fasteners these industrial tools are designed to operate on are also challenging to install or remove.
Hydraulic & Pneumatic torque tools can operate through the application of fluid pressure to a ram that extends and retracts, ratcheting the head. These specialized industrial torque wrenches are available i a wide variety of applied torque ranges, sizes and sensitivities.
Contribute Article
Disclaimer
Engineering Store
Engineering Training PDH
Products & Services
Engineering Design Data
Industrial News Buzz
Newsletter Register
Feedback
GD&T Training ASME Y14.5-2009
DFM Training
Contribute Article
Share |
