Engineers Edge
Pipe Flow Expert - Piping Design Calculations Software
Product and Services Directory | Advertise
Fluids Knowledge | Engineering Software
Click here for Software Trial Downloads
Pipe Flow Expert Engineering Calculation Software
Pipe Flow Expert will Calculate Pipe Pressure Drop and Flow in Pipe networks providing instant and accurate results that show you what is happening in your pipe system. It has an easy-to-use Isometric 3D drawing interface and comes with over 20 example systems. Pipe Flow Expert will model both open and closed loop pipe systems with multiple pumps, components, fittings and tanks, and it calculates flow rates, pipe pressure drops, friction losses, pump operating points and much more.
The reported results include:
  • Flow rates
  • Fluid velocities
  • Reynolds numbers
  • Friction factors
  • Pipe losses
  • Fitting losses
  • Component losses
  • Pump operating points
  • Pump head generated
  • NPSHa at pump inlet
  • Pressures at nodes
  • HGL values
The input and display of system information on the Pipe Flow Expert drawing and in the results tables can be shown in metric or imperial units to suit your preference and specific units for each item (such as flow rate) can also be configured and set on an individual basis as required. Pipe Flow Expert has been designed for the professional engineer who needs a powerful tool that has a class leading, easy to use and robust interface that makes it simple to design and analyze pipe networks.
Click Link Below to visit www.PipeFlow.co.uk
Calculate Pipe Pressure Drop and Flow in Pipe Networks
© Copyright, by Engineers Edge, All rights reserved.
Engineering Store
Products & Services
CAD Forum
Engineering Design Data
Industrial News Buzz
Engineering Specifications
Newsletter Register
Advertise
Feedback
