Engineers Edge Pipe Flow Wizard Engineering Software
Engineers Edge
Frequently Asked Questions
Product and Services Directory | Advertise
Fluids Knowledge | Engineering Software
Click here for Software Trial Downloads
 Pipe Flow Wizard
Pipe Flow Wizard is able to perform four different calculations depending on the known information. It can calculate:
  • Pressure Drops
  • Flow Rates
  • Size of Internal Diameters
  • Pipe Lengths
Pipe Flow Wizard will calculate results for LIQUIDS or COMPRESSED GASES.
A comprehensive Fluid Database is included with viscosity and density of common fluids.
PRESSURE DROP CALCULATION
When internal roughness, internal diameter, length, fittings, elevation change, and flow rate applicable to a pipe are known the PRESSURE DROP through the pipe can be calculated.
The type of flow, Reynold's number, friction factor, and fluid velocity are also displayed.
Find pressure drop given flow rate, pipe size, pipe length
FLOW RATE CALCULATION
\When internal roughness, internal diameter, length, fittings, elevation change, and available pressure applicable to a pipe are known the FLOW RATE through the pipe can be calculated.\
Find flow rate given pressure, pipe size, pipe length and fittings
INTERNAL PIPE DIAMETER CALCULATION
When internal roughness, length, fittings, elevation change, available pressure, and flow rate applicable to a pipe are known the MINIMUM INTERNAL DIAMETER of the pipe can be calculated.
Find internal diameter of pipe given availlable pressure, flow rate, pipe length, elevation and fittings
PIPE LENGTH CALCULATION
When internal roughness, internal diameter, fittings, elevation change, available pressure, and flow rate applicable to a pipe are known the MAXIMUM LENGTH of the pipe can be calculated.
Find pipe length given availlable pressure, flow rate, internal diameter, elevation and fittings
© Copyright, by Engineers Edge, All rights reserved.
Engineering Store
Products & Services
CAD Forum
Engineering Design Data
Engineering Motion
Newsletter Register
Advertise
Feedback
What's New at Engineers Store? more
13 3/8" Adjustable Male Human Figure Template
$17.98
GD&T Training ASME & ISO
DFM Training
