Pump Knowledge Menu | Progressive Cavity Pumps Suppliers
Progressive cavity pump, sometimes referred to " progressing cavity pump" is a pump that transfers fluid through a sequence of small, fixed shape cavities as an helix shaped rotor is rotated. The rotor is formed as a single helix shape of some length. The stator or cylinder is formed as a double-helix having twice (2X) the pitch of the rotor. As the helix shaped rotor rotates within the stator, the fluid is compressed and displaced along the length of the pump.
Typically, the rotor is made from a rigid metal and the stator or cylinder is fabricated from an elastomer or elastomer coated cylinder. The rotor and stator are designed with a known interference fit which ultimately creates the series of sealed chambers called cavities. These pumps are commonly used as metering pumps due to their constant flow attributes when when pumping of viscous or shear sensitive materials. Often a mechanically and electronically controlled flow meter is installed on the progressive pumps outlet. This flow meter is used to refine the flow and volume of the fluid or structure being pumped.
Typical applications include: Food & Beverage, Chemical, Biochemical, Pulp & Paper, Oil Gas & Petrochemical, any Industrial, Agricultural, Construction, Automotive, Fish industry, Electroplating, Ceramics, Pharmaceutical, Cosmetics, Confectionery Industry, Textile Industry, Wine Production, and more..
© Copyright 2000 - 2009, by Engineers Edge, LLC All rights reserved.
Disclaimer
