Random Links
Solder Joint - Bevel Joint Calculation / Formulae
Joint allowable stress in tension
Joint allowable stress in shear
Tensile stress in joint
Shear stress in joint
Strength check
s sA and t tA
Minimum thickness of connected parts
smin = max {s1, s2 }
where:
where:
SU
joint strength in tension (psi) [MPa]
kT
tension safety coefficient
SUS
joint strength in shear (psi) [MPa]
kS
shear safety coefficient
F
transferred force (lbs) [N]
b
width of connected parts (in.) [mm]
s
thickness of connected parts (in.) [mm]
Contribute Article
Disclaimer
Engineering Store
Engineering Training PDH
Products & Services
Engineering Design Data
Industrial News Buzz
Newsletter Register
Feedback
GD&T Training ASME Y14.5-2009
DFM Training
Contribute Article
Share |
