Random Links
V Belt Application
V and Flat Belt Design and Engineering Data
V-Belt Suppliers
Mechanical Drives & Belting Mechanical Drives & Belting is a leading distributor of industrial supplies including Conveyor Belting, AC/DC Motors, Speed Reducers, Bearings, Brakes, Clutches, Chain, Rotating Unions and much more! We are a company commited to serving our customers by providing solutions to boost efficiency, cut costs and reduce down time. www.larubber.com
General
V-belts are the workhorse within industry, available from virtually every distributor and adaptable to practically any drive.  They are presently available in a wide variety of standard sizes and types, for transmitting almost any amount of load power.
Operation
Typically, V-belts drives operate best at speeds between 1500 to 6000 ft/min ( 8 and 30 m/s).  For standard belts, ideal peak capacity speed is approximately 4500 ft/min (23 m/s).  Narrow V-belts, however, will operate up to 10,000 ft/min (50 m/s).
Advantages
V-belt drives permit large speed ratios and provide long life.  They are easily installed and removed, quiet, and low maintenance.
Limitations
V-belts will slip and creep, V-belts should not be used where synchronous speeds are requires.
Sizes - See V Belt Sizes for more.
Industrial V-belts are made in two types: heavy -duty (conventional, narrow), and light duty. Conventional belts are available in A, B, C, D and E sections.  Narrow belts are made in 3V, 5V, and 8V sections.  Light-duty belts come in 2L, 3L, 4L, and 5L sections.  Open-end belting is available in A, B, C, D, and E sections, and in some sizes for low-horsepower.
Agricultural belts are made in the same sections as conventional belts however, they are designated HA, HB, HC, HD, and HE: in double-V sections HAA, HBB, HCC, and HDD.
Automotive belts are made in six SAE-designated cross sections identified by the nominal top widths .38, .50, .69, .75, .88, and 1.00 in. (10, 12, 17, 19, 22, and 25 mm).
V-belts can be manufactured in any length within a fairly wide range.
Contribute Article
Disclaimer
Engineering Store
Engineering Training PDH
Products & Services
Engineering Design Data
Industrial News Buzz
Newsletter Register
Feedback
GD&T Training ASME Y14.5-2009
DFM Training
Contribute Article
Share |
