Engineering Design Data: Menu - 3D Printing
3D printers, printing technology.
Prev Page
Pages: 1 2 [3]
STL CAD Files For Rapid Prototyping
3D Printing - The STL file format has become the Rapid Prototyping industry's defacto standard data transmission format. This format approximates the surfaces of a solid model with triangles.
Storing ABS Filament Best Way
The best way to store ABS 3D Printing Filament. ABS filament is known for absorbing moisture, therefore it is a good ideal to store your ABS filament to minimize the contamination. Most of the time you can use an airtight container with a few desiccant packets.. However, some specialty filaments should be stored in an airtight container. PVA is notorious for absorbing humidity resulting is your filament printing very poorly. I have been using reusable vacuum sealed bags to store my filament. These can be purchased at Walmart or | Storing ABS Filament
Watertight 3D Printed Parts
Can you make 3D Prints Watertight? Can you calculate the volume of liquid your designs hold? Yes. Filament used:Refil Recycled PET 3D Printer used: Cocoon Create (Wanhao i3 V2) Software used:Autodesk Fusion 360 and Simplify3D 3D Printing Resources
Worlds First 3D Printed Metal Gun Video
Worlds First 3D Printed Metal Gun. Introducing metal 3D printing to the world as a viable solution for fully functional firearm prototypes. Its chamber sees pressure above 20,000 psi every time it is fired proving the material integrity provided by DMLS technology. The small components needed for the 1911 series gun proves DMLS can meet tolerances and accuracy. We're changing people's perspective about what 3D Printing can do and showing the technology is at a place where we can do this kind of thing and succeed. This technology is capable of fully functioning assemblies at full scale.
Prev Page
Pages: 1 2 [3]
© Copyright 2000 - 2017, by Engineers Edge, LLC All rights reserved.
Disclaimer
