Boiler Control Systems Design and Overview
Unified Facilities Criteria
Open: Boiler Control Systems
  • CONTENTS
  • INTRODUCTION
  • PURPOSE AND SCOPE
  • TYPES OF CONTROLS
  • CONTROL SELECTION
  • INSTRUMENT SELECTION
  • INSTRUMENT TUBING AND PIPING
  • INTERLOCK AND SAFETY REQUIREMENTS
  • EQUIPMENT RATING AND CLASSIFICATION
  • GENERAL REQUIREMENTS
  • CONTROL LOOPS
  • APPENDIX: REFERENCES
This document provides an introduction to criteria for the design of heating plant instrumentation. A heating plant contains one or more boilers. The plant may be an individual plant serving a single building or a compact group of buildings, or a central plant serving many buildings and facilities through an extensive distribution system. The heating plant instrumentation discussed is, in general, for a saturated steam power boiler heating plant. The typical saturated-steam power boiler heating plant discussed will operate at a design steam pressure of between 1.03 bar (15 psig) and 20.68 bar (300 psig), with a heating capacity of greater than 422 megajoule/h (400,000 Btu/h). The information provided may also be applicable to Low, Medium, and High Temperature Hot Water heating plants, but does not cover all of the requirements of those plants, such as control of water pressurization and circulation systems. The information may also be applicable to superheated-steam power plants, but does not cover the all of the requirements of those plants, such as steam extraction, reheating, steam turbine control, and cooling water controls. Instrumentation is a rapidly changing field. The options available in choosing and designing plant instrumentation are numerous. A boiler plant includes a large number of instrument items, all of which have to be specified in the procurement of a boiler plant. This document does not attempt to cover all details. Rather, its purpose is to present general guidelines for selecting and designing instrumentation for boiler plants.
Contribute Article
© Copyright 2000 - 2019, by Engineers Edge, LLC www.engineersedge.com
User Reviews/Comments:
Name:
Email: (Optional)
Comment:
