Engineering Design Data: Menu - Engineering White Papers > Design and Engineering General
Prev Page | Next Page
Pages: << 4 5 6 [7] 8 9 10 >>
Kents Mechanical Engineering Handbook
“Every engineer should make his own pocket-book, as he proceeds in study and practice, to suit his particular business.” The manuscript pocket-book thus begun, however, soon gave place to more modern means for disposing of the accumulation of engineering facts and figures, the index, the scrap-book, the collection of indexed envelopes, portfolios and boxes, the card catalogue, etc.
Design Bolted and Riveted Joints
Comprehensive source of information on bolted and riveted structural joints as well as an explanation of their behavior under various load conditions. Design recommendations are provided for both allowable stress design and load factor design. In both cases, major consideration is given to the fundamental behavior of the joint and its ultimate capacity.
High Strength Steel Welding Research
The application of high strength low alloy (HSLA) steels has been limited by the availability of suitable filler metals. Specifically, as the weld metal strength increases, the susceptibility to hydrogen- assisted cracking increases.
Weldment Reliability of High Strength Steel
The development of methods to control the diffusible hydrogen content during high strength steel welding was performed. The perfection of the use of irreversible weld metal hydrogen traps was demonstrated.
Petroleum Refining Volume 4
Petroleum Refining Volume 4 is devoted to the main equipment found in a refinery or a petrochemical complex
Petroleum Refining Volume 1
Refining has the function of transforming crude oil from various origins into a set of refined products in accordance with precise specifications and in quantities corresponding as closely as possible to the market requirements.
Power Transmission by Leather Belting
The advent of high-speed steel and of intensive methods of production has rendered the problem of belt maintenance one of the most important of the many that the factory manager has to solve.
Materials Helicopter Gears
Materials for Helicopter Gears - National Research Council
Gears Spur Load Capacity
Gears Spur and Helical Gears Calculation of Load Capacity
Analytical Mechanics Of Gears
This is not a text on gear design. It should form, however, a sound foundation upon which logical design practices and design data can be erected. These design structures, however, must be erected by the specialized engineering groups that have need of them. In the final analysis, there are so many unknown and uncertain factors that in critical cases our only answer is to “try and see.”
© Copyright 2000 - 2022, by Engineers Edge, LLC All rights reserved.
Disclaimer
