Engineering Design Data: Menu - Engineering White Papers > Engineering Materials
Next Page
Pages: [1] 2
Joining of Advanced Composites Engineering Design Handbook
Joining of Advanced Composites, Engineering Design Handbook
Engineering Physical Metallurgy
This book should be of particular aid to new engineering personnel, only recently engaged in industry, in coordinating their theoretical knowledge with the actual engineering practice they encounter and should also help them to better understand special treatises on physical metallurgy and heat treatment. More experienced engineers may use it to renew their theoretical knowledge on the subject.
Theory of Elasticity
Being written by physicists, and primarily for physicists, it naturally includes not only the ordinary theory of the deformation of solids, but also some topics not usually found in textbooks on the subject, such as thermal conduction and viscosity in solids, and various problems in the theory of elastic vibrations and waves.
Helical Compression Springs Engineering and Design
Design and Calculation for Springs Made From Circular Section Wire and Bar
Helical Extension Springs Engineering and Design
Selection and Use of Engineering Materials
There are two important principles that should apply to materials selection in engineering manufacture: (1) materials selection should be an integral part of the design process; (2) materials selection should be numerate.
Plastic Materials Properties
Plastic Materials Properties for Engineering Design - An overview of plastic materials, including their classification and an insight into their polymer structure , and a review of material properties and American Society for Testing and Materials standards for testing are presented. A brief discussion of environmental factors and their influence on properties is included.
Ceramic Matrix Composites Design Handbook, Volume 5
Ceramic Matrix Composites Handbook contains guidelines for determining the properties of composite material systems, their constituents, and generic structural elements, including test planning, test matrices, sampling, conditioning, test procedure selection, data reporting, data reduction, statistical analysis, and other related topics.
Metal Matrix Composites Handbook, Volume 4
Metal Matrix Composites volume 4 contains guidelines for determining the properties of composite material systems, their constituents, and generic structural elements, including test planning, test matrices, sampling, conditioning, test procedure selection, data reporting, data reduction, statistical analysis, and other related topics.
Composites Material Usage, Design, and Analysis Handbook, Volume 3
Volume 3 Composites Materials Handbook provides methodologies and lessons learned for the design, analysis, manufacture, and field support of fiber-reinforced, polymeric-matrix composite structures. It also provides guidance on material and process specifications and procedures for utilization of the material data presented in Volume 2.
Next Page
Pages: [1] 2
© Copyright 2000 - 2021, by Engineers Edge, LLC All rights reserved.
Disclaimer
