Bolt Torque and Clamping Force Formulas and Calculator per. JIS B 1083
Torque Design Menu
Torque Conversion Calculator
Strength of Materials
Bolt Preload Equations
Fastener Relation Between Torque and Clamping Force Formula and Calculator per. JIS B 1083
Preview Bolt Relation Between Torque and Clamping Force Formula and Calculator per. JIS B 1083
Bolt Thread nomenclature
Bolt Thread nomenclature Figure 1
Relationship between the applied tightening torque and bolt preload Ff
Equation 1
Tf = Ts + Tw = K · Ff · d
Tf = fastener tightening torque
Tw = bearing surface torque
Ts = shank (threaded) portion torque
K = Torque coefficient (Eq. 2)
d = nominal diameter of the screw thread
Equation 2
K = 1 / ( 2 · d ) ( P / π + µs · d2 · sec α' + µw · Dw )
P = screw thread pitch
µs = coefficient of friction between threads
d2 = pitch diameter of the thread
µw = coefficient of friction between bearing surfaces
Dw = equivalent diameter of the friction torque bearing surfaces
α' = flank angle at the ridge perpendicular section of the thread ridge
Equation 3
tan α' = tan (α) · cos(β)
α = thread half angle (30°, for example),
β = thread helix, or lead, angle.
Equation 4
β = l / ( 2πr )
r = thread radius (i.e., one-half the nominal diameter d)
l = thread lead = P
When the bearing surface contact area is circular,
Equation 5
Dw = 2/3 · ( Do3 - Di3 ) / ( Do2 - Di2 )
Do = outside diameter bearing surface contact area
Di = inside diameter bearing surface contact area
Torques attributable to the threaded portion of a fastener, Ts, and bearing surfaces of a joint, Tw, are as follows:
Equation 6
Ts = Ff / 2 ( P / π + µs · d2 · sec α' )
Equation 7
Tw = ( Ff / 2 ) · µs · Dw
Ff, P, µ, d2, α′, µs, and Dw are as previously defined.
Equation 8
Tfy = K · Ffy · d
where the yield clamping force Ffy is given by:
Equation 9
Ffy = σy · As / { 1 + 3 [ 2 / dA ( P / π + µs · d2 ·sec(α') ) ]2 }
σy = yield point or proof stress of the bolt
As = stress area of the thread
dA = diameter of a circle having an area equal to the stress areaof the thread
Other varibles have been identified previously
Equation 10
dA = ( 4 As / π )1/2
Torque Coefficients K for Metric Hexagon Head
Bolt and Nut Coarse Screw Threads
JIS B 0205 (ISO 724) thread standard
Coefficient of Friction K
Between Threads, µs
Between Bearing Surfaces, µw
0.08
0.10
0.12
0.15
0.20
0.25
0.30
0.35
0.40
0.45
0.08
0.117
0.130
0.143
0.163
0.195
0.228
0.261
0.293
0.326
0.359
0.10
0.127
0.140
0.153
0.173
0.206
0.239
0.271
0.304
0.337
0.369
0.12
0.138
0.151
0.164
0.184
0.216
0.249
0.282
0.314
0.347
0.380
0.15
0.153
0.167
0.180
0.199
0.232
0.265
0.297
0.330
0.363
0.396
0.20
0.180
0.193
0.206
0.226
0.258
0.291
0.324
0.356
0.389
0.422
0.25
0.206
0.219
0.232
0.252
0.284
0.317
0.350
0.383
0.415
0.448
0.30
0.232
0.245
0.258
0.278
0.311
0.343
0.376
0.409
0.442
0.474
0.35
0.258
0.271
0.284
0.304
0.337
0.370
0.402
0.435
0.468
0.500
0.40
0.285
0.298
0.311
0.330
0.363
0.396
0.428
0.461
0.494
0.527
0.45
0.311
0.324
0.337
0.357
0.389
0.422
0.455
0.487
0.520
0.553
Bolt and Nut Fine-Screw Threads
JIS B 0207 thread standard (ISO 724)
Between Threads, µs
0.08
0.10
0.12
0.15
0.20
0.25
0.30
0.35
0.40
0.45
0.08
0.106
0.118
0.130
0.148
0.177
0.207
0.237
0.267
0.296
0.326
0.10
0.117
0.129
0.141
0.158
0.188
0.218
0.248
0.278
0.307
0.337
0.12
0.128
0.140
0.151
0.169
0.199
0.229
0.259
0.288
0.318
0.348
0.15
0.144
0.156
0.168
0.186
0.215
0.245
0.275
0.305
0.334
0.364
0.20
0.171
0.183
0.195
0.213
0.242
0.272
0.302
0.332
0.361
0.391
0.25
0.198
0.210
0.222
0.240
0.270
0.299
0.329
0.359
0.389
0.418
0.30
0.225
0.237
0.249
0.267
0.297
0.326
0.356
0.386
0.416
0.445
0.35
0.252
0.264
0.276
0.294
0.324
0.353
0.383
0.413
0.443
0.472
0.40
0.279
0.291
0.303
0.321
0.351
0.381
0.410
0.440
0.470
0.500
0.45
0.306
0.318
0.330
0.348
0.378
0.408
0.437
0.467
0.497
0.527
Relationship between Bolt Elongation and Axial Tightening Tension
