Buckingham Reiner Equation and Calculator
Heat Transfer Engineering
Laminar flow of Bingham plastic fluids friction factor is given by the Buckingham-Reiner equation
τR = [ ( Po - PL ) R ] / 2 L
Q = [ ( π ( Po - PL ) R4 ρ )  / ( 8 µ L ) ] [ 1 - ( 4 τo ) / ( 3 τR ) + 0.333 ( τo / τR )4 ]
Po = Input Pressure (psi)
PL = Output Pressure (psi)
R = Radius or tube (ft)
ρ = Density of Fluid (ppg)
µ = Viscosity of Fluid (cP)
L = Length (ft)
τo = Torsion Stress (psi)
τR = Shear Stress at the Tube Wall (psi)
Q = Mass Flow Rate (lb/s)
ppg = pounds per gallon
cP = Poise
Note: When τo  is zero, the Bingham model reduces to the Newtonian model and the final equation presented above reduces appropriately to the Hagen-Poiseuille equation.
Bird, R.B., Stewart, W.E. and Lightfoot, E.N. (2002). Transport Phenomena (Second Ed.). John Wiley & Sons,Chapter: 8, Page: 260.
