Casing and Multiple Strings of Tubing Flow Rate Formula and Calculator
Pressure Vessel Pipes Design Engineering ASME
Annular Flow Capacity Between Casing and Multiple Strings of Tubing Formula and Calculator
Annular capacity between casing and multiple strings of tubing, bbl/ft:
Ca =[ Dh2 - ( T12 + T22 + T32 ) ] / 1029.4
Annular capacity between casing and multiple strings of tubing, ft/bbl:
Ca = 1029.4 / [ Dh2 - ( T12 + T22 + T32 ) ]
Eq. 3
Annular capacity between casing and multiple strings of tubing, gal/ft:
Ca = [ Dh2 - ( T12 + T22 + T32 ) ] / 24.51
Eq. 4
Annular capacity between casing and multiple strings of tubing, ft/gal:
Ca = 24.51 / [ Dh2 - ( T12 + T22 + T32 ) ]
Eq. 5
Annular capacity between casing and multiple strings of tubing, ft3/linft:
Ca = [ Dh2 - ( T12 + T22 + T32 ) ] / 183.5
Eq. 6
Annular capacity between casing and multiple strings of tubing, linft/ft3:
Ca = 183.35 / [ Dh2 - ( T12 + T22 + T32 ) ]
Ca = Annular capacity
Dh =Casing or Hole size ID (in.)
T1 = tubing No. 1
T2 = tubing No. 2
T3 = tubing No. 2
Example: Using three strings of tubing:
Dh = casing — 9-5/8 in. - 47 lb/ft ID = 8.681 in.
T1 = tubing No. 1 - 3-1/2 in. — OD = 3.5 in.
T2 = tubing No. 2 - 3-1/2 in. — OD = 3.5 in.
T3 = tubing No. 3 - 3-1/2 in. — OD = 3.5 in.
Annular capacity linft/ft3
Ca = 183.35 / [ 8.6812 - ( 3.52 + 3.52 + 3.52 ) ]
Annular capacity = 4.7487993 linft/ft3
Reference: Lapeyrouse, N. J., 2012, Formulas and Calculations for Drilling, Production and Workover, Third Edition
