Critical Pressure and Temperature Cavett Correlation Calculation
Heat Transfer Engineering
Thermodynamics Resources
Fluids Engineering and Design Data
Critical Pressure and Temperature Cavett Correlation for Oil Formula and Calculator
Related (Basic Membership Min Required):
New Correlation for Calculating Critical Pressure of Petroleum Fractions
Preview: Critical Pressure and Temperature Cavett Relation Calculator
Critical Pressure Cavett Relation Formula
Pc = 10(2.829) + ( 0.0009112 · Tb ) - ( 0.0000030175 · Tb2 ) + (0.0000000015141 · Tb3) - ( 0.000020876 · Tb · API ) + (0.000000011048 · Tb2 · API ) + ( 0.0000000001395 · Tb)2 · API
Critical Temperature Cavett Method Formula
Tc = 768.071 + ( 1.7134 · Tb ) - ( 0.0010834 · Tb2 ) + (0,0000003889 · Tb3) - ( 0,00089213 · Tb · API ) + (0,00000053095 · Tb2 · API ) + ( 0,000000032712 · Tb2 · API2 )
Tb = Boiling Point Temperature (°F)
API = API Gravity of oil (API)
Pc = Critical Pressure (Psi)
Tc = Critical Temperature (°F)
Crude oil is classified as light, medium, or heavy according to its measured API gravity.
Light crude oil has an API gravity higher than 31.1° (i.e., less than 870 kg/m3)
Medium oil has an API gravity between 22.3 and 31.1° (i.e., 870 to 920 kg/m3)
Heavy crude oil has an API gravity below 22.3° (i.e., 920 to 1000 kg/m3)
Extra heavy oil has an API gravity below 10.0° (i.e., greater than 1000 kg/m3
Wikipedia
