Equal Weight Solid Shaft and Hollow Shaft of Same Length Formula and Calculator
Beam Deflection and Stress Calculators Formulas & Structural Analysis
Strength and Mechanics of Materials Menu
Equal Weight of Solid Shaft Vs. Hollow Shaft of Same Length Formula and Calculator
When materials of both shafts are same
D = Do ( 1 - K4 )(1/2)
When materials of shafts are different
D = Do { ( 1 - K4 ) ( wh / ws ) } (1/2)
Eq. 3
ratio of inner to outer diameter of hollow shaft
K = Di / Do
Eq. 4
Weight of hollow shaft
wh = π [ ( Do / 2 )2 - ( Di / 2 )2 ] L ρ
Eq. 5
Weight of solid shaft
ws = π ( Do / 2 )2 ] L ρ
Do / 2 = radius of outer diameter
Di / 2 = radius of inner diameter
Where
Do = outside diameter of hollow shaft, m (in)
Di = inside diameter of hollow shaft, m (in)
D = diameter of solid shaft, m (in)
K = ratio of inner to outer diameter of hollow shaft
wh = weight hollow shaft, N (lbf)
ws = weight of solid shaft, N (lbf)
ρ = density kg / m3 , (lbs / in3 )
L = length of cylinder
Figure 1 Hollow and Solid Shaft Dimensions Declarations
References
1. Lingaiah, K., and B. R. Narayana Iyengar, Machine Design Data Handbook, Engineering College Cooperative, Bangalore, India, 1962.
- Volume of Hollow Cylinder Formula and Calculator
- Solid Cylinder Volume and Surface Area Equation and Calculator
- Solid Shaft Equivalent of Hollow Shaft Strength Formula and Calculator
- Diameter Combined Torsion and Bending Equation and Calculator
- Solid Shaft with Simple Bending Diameter Equation and Calculator
