Flow through Convergent Nozzle Equations and Calculator
Isentropic Flow through Convergent Nozzle Equations and Calculator
Isentropic flow of compressible fluid from a large tank through a convergent nozzle, as shown in Fig. 1 indicates that the pressure, mass density, and temperature (p1, ρ1, and T1) at a point within the tank. Since the tank is "large," velocity here is assumed to be near zero. Also indicated on Fig. 1 are the same parameters as well as the velocity of flow and area of the nozzle (p2, ρ2, T2, v2, and A2) at the exit of the nozzle. Also indicated is p2', the pressure outside the tank.
Figure 1, Convergent nozzle.
Preview Isentropic Flow through Convergent Nozzle Calculator
In a convergent nozzle, flow through the nozzle's throat will be either sonic or subsonic. If flow is sonic, the Mach number is equal to unity, and the ratio p2/p1 must be equal to the "critical pressure ratio" as defined by
where
(p2/p1)c = critical pressure ratio
k = specific heat ratio
If flow through the throat is subsonic, the ratio (p2/p1)c will be larger than (p'2/p1).
Obviously, in order to have appreciable flow from the tank through the nozzle out of the tank, pressure inside the tank must be greater than pressure outside the tank (that is, p1 > p'2). If the pressure drop is small [(p2/p1) >(p2/p1)c], flow through the nozzle will be subsonic and the pressure at the exit of the nozzle will be the same as the pressure outside the tank (p2 = p'2). In this case the weight flow rate can be determined from the equation
where:
G = weight flow rate, lbs/ft2, (N/m2)
A2 = throat area, ft2, (m2)
g = acceleration of gravity, ft/sec2 (m/sec2)
p1 = pressure inside the tank, lbs/ft2, (N/m2)
p2 = pressure inside the tank, lbs/ft2, (N/m2)
γ1 = specific weight of fluid inside the tank, lbs/ft3, (N/m3)
R = Gas constant, ft/°R, (m/K)
If the pressure drop increases (either by increasing p1 or decreasing p'2, or both), flow through the
nozzle will remain subsonic until the point is reached where the ratio p'2/p1 is equal to the critical
pressure ratio (p2/p1)c, At this point, flow through the nozzle will be sonic and the pressure at the exit
of the nozzle will be the same as the pressure outside the tank (p2 = p'2). In this case, the weight flow
Eq. 3
where T1 is the absolute temperature of the fluid inside the tank, R is the gas constant, and other terms are as defined above for equation 2.
If the pressure drop increases further [beyond the point where the ratio p'2/p1 is equal to the critical
pressure ratio (p'2/p1)c , flow through the nozzle will remain sonic and the pressure at the exit of the
nozzle will be greater than the pressure outside the tank (p2 > p'2). However, the weight flow rate will
not increase. Thus, no matter how much p1 is increased or p'2 is decreased, if the ratio p'2/p1 is less
than the critical pressure ratio (p2/p1)c the weight flow rate will be the same as that where the ratio
p'2/p1 is equal to the critical pressure ratio. In this case the weight flow rate can be determined from
equation 3 provided the value substituted for p1 is the pressure that makes the ratio p'2/p1 equal to
the critical pressure ratio (p2/p1)c.
Schaum's Outline of Fluid Mechanics and Hydraulics
- Convergent Divergent Nozzle Flow Velocity and Area Equation and Calculator
- Isentropic Flow Relationships
- Isentropic Process Thermodynamic
- Isentropic Pressure and Volume
- Calculation of Mass Flow Rate Equation
- Mass Flow Rate Fluids Flow Equation
- Convergent Nozzle Flow Velocity and Area Equation and Calculator
- Continuity Equation Fluids Flow
- Convergent-Divergent Nozzle Flow Velocity and Area Equation and Calculator
- Viscosity of Fluid with Falling Sphere at Terminal Velocity Equation and Calculator Measurement of Viscosity in a Vertical Falling Ball Viscometer Calculator
- Pitot-Static Tube Velocity of Fluid Flow Measurement Calculator and Equation
- Velocity of Water Due To Head in Feet Table
- Conservation of Mass Fluids - Fluid Flow Hydraulic and Pneumatic
- Velocity of Escaping Compressed Air Equation and Calculator
- Total Head Pressure Velocity Equations and Calculator
- Pipe Whip If a pipe were to rupture, the reaction force created by the high velocity fluid jet could cause the piping to displace and cause extensive damage
- Fluid Flow Open Channel Calculator Chezy and Manning's equation to determine the wetted perimeter, hydraulic radius, flow area, Chezy coefficient and flow velocity
- Flow Velocity Profiles Not all fluid particles travel at the same velocity within a pipe.
- Average (Bulk) Velocity Ia single average velocity to represent the velocity of all fluid at that point in the pipe.
- Compressibility of a Fluid Equations and Calculator
- Compressibility of Liquids Equations and Calculators
- Flow Through a Sluice Gate Formula and Calculator
