Pad Foundation Design per Eurocode 2 Equations and Calculator
Pad Foundation Design Equations and Calculator per Eurocode 2
Pad foundation design, Geotechnical design calculations include:
- Allowable bearing capacity by Brinch Hansen
- Preliminary sizing of pad footing
- Ultimate bearing pressure
- Flexure design
- Determine K for respective MED
- Area of tensile reinforcement
- Number of reinforcement bars
- Minimum reinforcement requirements
- Maximum reinforcement requirement
- Shear design
- Design punching shear stress
- Concrete shear capacity (without shear reinforcement)
EN 1992 Eurocode 2 applies to the design of buildings and other civil engineering works in plain, reinforced and prestressed concrete. It complies with the principles and requirements for the safety and serviceability of structures, the basis of their design and verification that are given in EN 1990: Basis of structural design. EN Eurocode 2 is concerned with the requirements for resistance, serviceability, durability and fire resistance of concrete structures.
Precision:
Input- Insert the dimensions of the foundation and the column cross-section, the loads with their respective safety factors, the material properties and the groundwater level-only if it's applicable.
Section | ||
Column size (x,y) | m | |
m | ||
Depth (h) | m | |
Width (B) (x axis) | m | |
Concrete cover | m | |
Length (l) (y axis) | m |
Load and material | ||
Dead load | kN | |
Live load | kN | |
Moment | kNm | |
Concrete grade | ||
Steel grade | ||
Bar size |
Allowable bearing capacity and soil properties | ||
Internal shear angle (Φ) | ° | |
Cohesion (C) | kN/m2 | |
Unit weight of soil | kN/m3 | |
Depth of the foundation from the ground level | m | |
Bearing capacity safety factor |
Ground water effect | ||
m |
This application Requires Premium Membership to execute calculations
Output results - This will calculate the preliminary sizing (length) in the section table and design a pad foundation for flexure and shear in the tables below from the design input data in the table above.
Geotechnical analysis | ||||
Allowable bearing capacity | kN/m2 | |||
Ultimate design pressure | kN/m2 | |||
Flexure analysis | ||||
Along the shorter span | Along the longer span | |||
Bending moment (MED) | kNm | kNm | ||
Effective depth (d) | m | m | ||
K value | ||||
Required steel area (As) | mm2 | mm2 | ||
Reinforcement bar spacing | mm | mm | ||
Provided steel area (As) | mm2 | mm2 |
Shear analysis | Remark | ||
Shear stress at the face of the column (vED,max) | MPa | ||
Concrete maximum shear strength (vRd,max) | MPa | ||
Beam shear stress at distance d from the column (vED) | kN/m | ||
Mpa | |||
Punching shear stress at controlled perimeter u1 (vED) | kN/m | ||
MPa | |||
Steel ratio | % | ||
Concrete shear resistance (vRD,c) | MPa |
Equations used for Steel Column Design Calculator
Alazar Woldeyohannes
Master's program in Structural Engineering in the School of Mechanical, Aerospace and Civil Engineering
University of Manchester
Email available on request
- Steel Column Design per. EUROCODE 2 Calculator and Equations
- Reinforced Concrete Flat Slab per. Eurocode 2
- Reinforced Concrete Beam Design per. Eurocode 2
- Slab Punching Shear Calculation Spreadsheet
- ASTM C14 Concrete Sewer Pipe Dimensions and Weights
- ASTM C76 Reinforced Concrete Sewer Pipe Dimensions and Weights
- Concrete Long Term Creep Deflections per. ACI 318 Equations
- Concrete Modulus of Elasticity Equations and Calculator
- Concrete Modulus of Rupture Equations and Calculator
- Concrete Splitting Tensile Strength Test Equations and Calculator
- AASHTO LRFD Bridge Slab Design Calculator Spreadsheet - This spreadsheet was created to aid in the rapid design and/or checking of Bridge Decks or Reinforced Concrete Boxes in accordance with AASHTO 2004 LRFD.
- Bridge Concrete Slab Design Spreadsheet Calculator
- Asphalt and Concrete Pavement Recycling guidance for preparing plans and specifications and for ensuring the quality of recycled bituminous concrete. Premium Membership Required
- Concrete Slab Volume Estimator Calculator Estimate the require concrete volume to fill the width, height and depth given.
- Concrete Footer Volume Estimator Calculator Calculate required concrete volume to fill footing data given.
- Concrete Column Volume Estimator Calculator Estimate the required concrete to fill the quantity, height and diameter of concrete columns.
- Concrete Rectangular Beam Section Analysis Calculator Concrete Rectangular Beam Section Analysis Calculator Beam or One-Way Type Shear per Per ACI 318-05 Code
- Concrete Structural Designers Guide, High Performance Premium Membership Required
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Nominal Axial Compressive Strength Non-prestressed Concrete Columns per. ACI 318-14 American Concrete Institute (ACI) Formulas and Calculator
- Reinforced Concrete Beam Design per. ACI 318-08 Calculator Spreadsheet
- Analysis and Design of Concrete T-Beams Spreadsheet Calculator
- Circular Mander Concrete Stress-Strain Section Calculator
- Cantilever Concrete Slab Design per IS 456:2000 Spreadsheet Calculator
- Composite Rectangular Beam and Columns Spreadsheet Calculator
- Concrete Anchor Pullout Tension Design Calculator Concrete Anchor subjected to Tension Pullout Force per ACI 318-02.
- Concrete Anchor Group Pullout Tension Design Calculator Concrete Anchor Tension Pullout Force Design Calculator per ACI 318-02.
- Concrete Anchor in Tension and Shear Near Edge Concrete Anchor Tension Pullout Force Design Calculator per ACI 318-02.
- Concrete Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02 Calculator Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02
- Concrete Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02 Calculator Case # 5 Anchor Group Tension and Shear Fasteners Near Two Edges Based on ACI 318-02
- Concrete Column Base Plate Design Base plates are usually used to distribute column loads over a large area.
- Concrete Floor Slabs Design Requirements and Equation Floor slabs on grade should be analyzed for adequate structural live loads.
- Concrete Foundation Anchor Bolts Design and Selection Anchor bolt is used to attach objects or structures to concrete.
- Concrete Pad Foundation Design Spreadsheet Calculator
- Concrete Reinforced Beam Design to BS8110 Calculator
- Concrete Creep, Shrinkage Factors and Tensile Strength Calculation per. BS EN 1992
- Concrete Slab on Grade according to New Zealand Standards Spreadsheet Calculator
- Flat Concrete Slab Design Spreadsheet Calculator per. BS EN 1992-1: 2004
- Flexural Crack Width in Concrete Calculator per. BS EN 1992-1: 2004
- Manual of Concrete Design , ACI
- Retaining Wall Concrete Design Spreadsheet Calculator per. EN 1992-1: 2004
- Rectangular Concrete Beam Section Analysis Beam Torsion and Shear Rectangular Concrete Beam Section Torsion and Shear Per ACI 318-05 Code
- Rectangular Concrete Beam Section Analysis Crack Control - Distribution of Flexural Reinforcing Flexure, Shear, Crack Control, and Inertia for Singly or Doubly Reinforced Sections Per ACI 318-05 Code
- Rectangular Concrete Beam and Slab Section Analysis Crack Control, and Inertia for Singly or Doubly Reinforced Sections Per ACI 318-05 Code
- Rectangular Mander Concrete Stress-Strain Section Calculator
- Reinforced Concrete Analysis and Design for Torsion Spreadsheet Calculator
- Reinforced Concrete Element Design Spreadsheet Calculator per. EN 1992-1: 2004
- Reinforced Concrete Elements Design and Analysis Spreadsheet Calculator
- Reinforced Concrete Handbook, for Engineers, Architects, and Contractors Premium Membership Required to view Document/Book
- Structural Design Criteria for Buildings Criteria for the design of buildings using cast-in-place or precast construction with plain, reinforced, or prestressed concrete.
