Pipe Repair Limited by Allowable Strain in the Repair Calculator
Pipe Repair Limited by Allowable Strain in the Repair Laminate Formulas and Calculator per. ISO 24817
Formulae (1) and (2) shall be used when it is assumed that the repair is limited by the allowable strain of the repair laminate. In the circumferential direction, laminate thickness, tmin (expressed in millimetres) is given by Equation (2)
Membership (Premium) required to access calculator
Preview Pipe Repair Thickness Using Wrapped Laminate Calculator
NOTE It is possible that when using Equation(1) , that negative repair thickness values are calculated. This implies that the remaining wall thickness is sufficient to withstand the applied loads.
Design formulas limited by allowable stress in the substrate formulas by
ϵ c = 1 E c t m i n ( p e q D 2 + v F e q π D ) p s D 2 E c t m i n p l i v e D 2 ( E c t m i n + E s t s )
In the axial direction, the minimum repair laminate thickness, tmin (expressed in millimetres) , is given by
Eq. 2:
t m i n , a = 1 ϵ a ( F e q π D 1 E a P e q D 2 v E c )
If the repair is applied at zero internal pressure, i.e. plive = 0, and axial loads can be neglected, i.e. buried pipelines, then Eq. 2 can be rearranged to give:
Eq. 3
t m i n = D 2 ϵ c E c ( p e q p s )
The design repair thickness, tdesign, shall be taken as the maximum value determined from either Equation (1) or (2) .
Equation (1) to (3) are valid for repair thickness
Eq. 4
t d e s i g n < D 12
The assumptions made in deriving Equations (1) to (3) are that the substrate is elastic and only contributes to the load-sharing up to the allowable stress (of the substrate) .
In Equation 6, the contribution of Feq shall be taken as positive.
peq is defined as:
Eq. 5a
p e q = p [ 1 + 16 ( π D 2 p ) 2 ( f s h + 2 D M t o ) 2 ] f o r p 4 π D 2 ( F s h + 2 D M t o )
Eq. 5b
p e q = p + 4 π D 2 ( f s h + 2 D M t o ) f o r p < 4 π D 2 ( F s h + 2 D M t o )
Feq is defined as:
Eq. 6
F e q = π 4 p D 2 + F a x 2 + 4 F s h 2 + 4 D M a x 2 + M t o 2
where
plive is the internal pressure during repair installation, expressed in megapascals;
εc is the repair laminate circumferential strain, expressed in millimetres per millimetre;
εa is the repair laminate axial strain, expressed in millimetres per millimetre
D is the original external diameter
MAWP is the Maximum Allowable Working Pressure
Ea is the axial tensile modulus of the repair laminate, expressed in megapascals;
Ec is the circumferential modulus of the repair laminate, expressed in megapascals;
Es is the tensile modulus of substrate, expressed in megapascals;
D is the original external diameter, expressed in millimetres;
Feq is the equivalent axial load, expressed in newtons [see Eq. 4] ;
ν is the Poisson’s ratio of the repair laminate (see Annex B for definition);
s is the allowable stress of the substrate material, expressed in megapascals;
peq is the equivalent internal pressure, expressed in megapascals [see Eq. (3)] ;
ps is the MAWP, expressed in megapascals, which is defined according to the relevant defect assessment code;
ts is the minimum remaining substrate wall thickness, expressed in millimetres.
p is the required internal design pressure, expressed in megapascals;
Fsh is the applied shear load, expressed in newtons;
Mto is the applied torsional moment, expressed in newton millimetres;
Fax is the applied axial load, expressed in newtons;
Max is the applied axial moment, expressed in newton millimetres.
The design repair thickness, tdesign (expressed in millimetres) , shall be the maximum value of tm and tmin,a determined from Formulae (1) and (2) .
If the purpose of the repair system is to strengthen an undamaged section to carry additional bending or other axial loads, the value of Feq shall be taken to be the increased total axial load requirement and the value of ps shall be the MAWP after the defect has been assessed.
Formulae (1) and (2) are valid for repair thickness
Eq. 5
t d e s i g n =< D 12
The assumption made in deriving Formulae (1) and (2) is that the substrate is elastic.
  • International Standard ISO 24817, Petroleum, petrochemical and natural gas industries - Composite repairs for pipework - Qualification and design, installation, testing and inspection
