Pipe Repair Using Wrapped Laminates per ISO 24817 Calculator
Pipe Repair Thickness Using Wrapped Laminate Stress Design Formulas and Calculator per. ISO 24817
These equations are for the design of pipe wrap material and thickness of composite material in situations for damages commonly encountered in oil, gas, utility pipe work systems and vessels. Calculations will determine the minimum thickness required in the wrap laminate.
Membership (Premium) required to access calculator
Preview Pipe Repair Thickness Using Wrapped Laminate Calculator
Design formulas limited by allowable stress in the substrate formulas
Equations (1) and (2) shall be used when it is assumed that the repair thickness is limited by the allowable stress in the substrate.
In the circumferential direction, the minimum repair laminate thickness, tmin (expressed in millimeters) , is given by
Eq. 1 Pipe Repair Using Wrapped Laminate Stress Design
In the axial direction, the minimum repair laminate thickness, tmin (expressed in millimeters) , is given by
Equation 2
NOTE It is possible that when using Equation 2, that negative repair thickness values are calculated. This implies that the remaining wall thickness is sufficient to withstand the applied loads in the axial direction.
In Equation 2, the contribution of Feq shall be taken as positive.
peq is defined as:
Eq. 3a
Eq. 3b
Feq is defined as:
Eq. 4
where
D is the original external diameter
MAWP is the Maximum Allowable Working Pressure
Ea is the axial tensile modulus of the repair laminate, expressed in megapascals;
Ec is the circumferential modulus of the repair laminate, expressed in megapascals;
Es is the tensile modulus of substrate, expressed in megapascals;
D is the original external diameter, expressed in millimetres;
Feq is the equivalent axial load, expressed in newtons [see Eq. 4] ;
ν is the Poisson’s ratio of the repair laminate (see Annex B for definition);
s is the allowable stress of the substrate material, expressed in megapascals;
peq is the equivalent internal pressure, expressed in megapascals [see Eq. (3)] ;
ps is the MAWP, expressed in megapascals, which is defined according to the relevant defect
assessment code;
ts is the minimum remaining substrate wall thickness, expressed in millimetres.
p is the required internal design pressure, expressed in megapascals;
Fsh is the applied shear load, expressed in newtons;
Mto is the applied torsional moment, expressed in newton millimetres;
Fax is the applied axial load, expressed in newtons;
Max is the applied axial moment, expressed in newton millimetres.
The design repair thickness, tdesign (expressed in millimetres) , shall be the maximum value of tmin,c and tmin,a determined from Formulae (1) and (2) .
If the purpose of the repair system is to strengthen an undamaged section to carry additional bending or other axial loads, the value of Feq shall be taken to be the increased total axial load requirement and the value of ps shall be the MAWP after the defect has been assessed.
Formulae (1) and (2) are valid for repair thickness
Eq. 5
The assumption made in deriving Formulae (1) and (2) is that the substrate is elastic.
- International Standard ISO 24817, Petroleum, petrochemical and natural gas industries - Composite repairs for pipework - Qualification and design, installation, testing and inspection
- Pressure Vessel, Thin Wall Hoop and Longitudinal Stresses Equation and Calculator
- Pressure Vessel , Thin Wall Hoop Stress Calculator Strength of Materials
- Circular Ring Stress Analysis no. 11 Roarks Formulas for Stress and Strain Equations and Calculator
- Pipe Size Schedule Chart
- Pipe Threads for Pressure Joints per. EN 10226-1 Calculator
- Appliance Natural Gas Pipe Flow Rate Capacities for up to 200 ft of pipe based on a specific gravity of 0.60.
- Mass Flow Rate for Gas Pipeline Blowdown through Hole or Orifice Excel Spreadsheet Calculator
- Dimensions of Ductile Iron Pipe Special Pressure Classes (customary U.S. units)
- Pipe Sizes for Fuel Oil Table Oil Suction -The following are the recommended Nominal Size for Fuel Oil Suction line from the storage tank to the supply pump.
- Gravity Sewer Pipe (solid wall) Table Dimensions and Sizes
- Transmission Gas Line Isothermal Flow Equations and Calculator - The steady-state, isothermal flow behavior of gas in pipelines is defined by a general energy equation of the form:
- Head Changes Caused by Pipe Size Enlargement Formula and Calculator
- Head Changes Caused by Pipe Size Sudden Reduction Formula and Calculator
- Natural Gas Pipe Flow Rate Requirement Formulas and Calculator
- Liquid Pressure Drop in Pipe and Pipe Fittings Spreadsheet Calculator
- Pipe Enlargement and Reduction Head, Heat and Minor Losses Formula
- Flow of Water in Pipes Equations and Calculator
- Flow Rate of Steam in Schedule 40 Pipe Tables
- Pipe Support Hanger Spacing and Pipe Wall Thickness Table 1.0 suggests minimum pipe hanger spacing for use unless exceeded by the local authority having jurisdiction or engineering calculations.
- Pipe Support Spacing For Deflection Control Design Calculator
- Suggested Maximum Spacing Between Hanger Supports for PVC and CPVC Support spacings for PVC and CPVC pipe systems are influenced by operating temperatures. The tables below recommends horizontal spacing based on pipe size, schedule, material (PVC or industrial grade CPVC), and operating temperature.
- Head Loss at Pipe Entrance Equations and Calculator using the head loss coefficient and head loss of a fluid at a smooth bellmouth pipe entrance.
- Head Loss at Pipe Abrupt Exit Equations and Calculator of a fluid.
- Head loss and head loss coefficient equation and calculator of a fluid in across a screen (circular metal wire mesh) inside a pipe.
- Heat Loss or Gain From Pipe Excel Spreadsheet Calculator
- Maximum Storm Drain Pipe Flow Rate per. International Plumbing Code (IPC 2018) Table 1106.2
- Head coefficient and head loss across angled louvers inside a pipe equation and calculator.
- Pressure Losses for Fluid Flow in 90° Pipe Bends
- Straight Pipe Under Internal Pressure Formula and Calculator per. ASME B31.5
- Storm Drain Pipe Sizing Formula and Calculator
- Allowable Stresses for Pipe and Tube B36.10M - Steel pipe is manufactured by several processes. Seamless pipe (Type S), made by piercing or extruding, has no longitudinal seam. >
- Design for Pipe and Tube Forming Premium Membership Required
- Design for Stainless Steel Pipe and Tube Welding
