Solid Bolted Shaft Coupling Design Equations and Calculator
Solid Bolted Shaft Coupling Design Equations and Calculator.
Power Capacity P = π2NnDpD2bτy / 4
Key FS = πDNbLτy / P
Shaft FS = π2ND3τy / 8P
If, the bolts and nuts have same materials and FS, then:
Bolt diameter min. Db = ( D3 / ( 2nDp ) )1/2
Symbols used:
D = Shaft diameter (mm)
Dp= Pitch circle diameter of bolts (mm)
Db = Bolt diameter (mm)
n = Number of bolts
b = Width of key (mm)
L = Length of key and hub (mm)
P = Power transmitted (watt or in SI base units kg-m2-s-3)
FS = Factor of safety
N = Shaft speed (rpm)
τy = Shear yield stress (Pa)
Mechanical Engineers Databook, Carvil
