Solid Rectangular Section Torsional Deformation and Stress Torsional Deformation Stress Equation and Calculator
Torsional Deformation and Stress Solid Rectangular Section Equations and Calculator
Preview Torsional Deformation and Stress Solid Rectangle Section Calculator
θ = T L / K G
at the midpoint of each longer side for a ≥ b
θ - angle of twist (radians)
T = Twisting or torque moment force-length, (in-lbs, N-mm)
L = Length (in, mm)
a = Distance as indicated (in, mm)
b = Distance as indicated (in, mm)
τ = Unit shear stress force / area (lbs/in2, N/mm2)
G = Modulus of rigidity force / area (lbs/in2, N/mm2)
