Engineering Design Data: Menu - civil engineering
Civil engineering architecture related
Prev Page | Next Page
Pages: 1 2 3 [4] 5
Shear Walls Design Review
In structural engineering, a shear wall is a wall composed of braced panels (also known as shear panels) to counter the effects of lateral load acting on a structure.
Pressure on Submerged Curved Surfaces Equation
Pressure on Submerged Curved Surfaces Equation. The hydrostatic pressure on a submerged curved surface (Fig. 1) is given.
Photogrammetry Calculations Review
Photogrammetry is the art and science of obtaining reliable measurements by photography (metric photogrammetry) and qualitative evaluation of image data (photo interpretation).
Settlement Under Foundations Calculations
The approximate relationship between loads on foundations and settlement is...
Allowable Column Stress for Buildings
The AISC specification for allowable-stress design (ASD) for buildings provides two formulas for computing allowable compressive stress..
Concrete Column Base Plate Design
Base plates are usually used to distribute column loads over a large enough area of supporting concrete construction that the design bearing strength of the concrete is not exceeded.
Load & Resistance Factor Design for Shear in Buildings
Load & Resistance Factor Design for Shear in Buildings Based on the American Institute of Steel Construction (AISC)specifications for load-and-resistance factor design (LRFD) for buildings, the...
Soil Loading Under Pavement
Soil Loading Under Pavement, also called California Bearing Ratio.
Soil Permeability Review
The coefficient of permeability k is a measure of the rate of flow of water through saturated soil under a given hydraulic gradient i, cm/cm, and is defined in accordance with Darcy's law as:
Bearing Capacity of Soil Equation and Calculator
The approximate ultimate bearing capacity under a long footing at the surface of a soil is given by Prandtl's equation
Pages: 1 2 3 [4] 5
© Copyright 2000 - 2018, by Engineers Edge, LLC All rights reserved.
Disclaimer
