Concrete Foundation Anchor Bolts Design |
Anchor bolts are a vital link between equipment and the foundation. Unfortunately, designers often overlook important points concerning anchor bolts, such as how long and strong they should be and the amount of preload. |
Shrinkage Values of Domestic Hardwoods |
The following provides facts about the moisture-shrinkage relationship of wood. A table of shrinkage values for North American hardwoods and softwoods is provided after the text. |
Structural Column Base Plates Engineering Design |
A column or pillar in architecture and structural engineering is an structural element that transmits, through compression, the weight of the structure above to other structural elements below. |
Structural Load Bearing Plates |
To resist a beam reaction, the minimum bearing length N in the direction of the beam span for a bearing plate is determined by equations for prevention of local web yielding and web crippling. |
Load Bearing Walls Review Design , Equation, Wall Stud Spacing Table |
Load Bearing Walls Review, Equation and Wall Stud Spacing Design Table. These are subject to axial compression loads in addition to their own weight and, where there is eccentricity of load or lateral loads, to flexure. Load-bearing walls may be designed in a manner similar to that for columns but including the design requirements for non-load-bearing walls. |
Shear Walls Design Review |
In structural engineering, a shear wall is a wall composed of braced panels (also known as shear panels) to counter the effects of lateral load acting on a structure. |
Photogrammetry Calculations Review |
Photogrammetry is the art and science of obtaining reliable measurements by photography (metric photogrammetry) and qualitative evaluation of image data (photo interpretation). |
