1 Attachment(s)
Spinning / Twist Discs .
Im not sure if this is the correct place to post this?
Im looking for help on how to have 2 discs which are the size of a 50 cent piece (double the size of a US quarter) in diameter. There are going to be 2 of them stacked on to of each other and I need some sort of solution to be able to spin or twist the top disc to reveal the numbers on the bottom disc. Im attaching a image to help explain what I need.
I haven't created the 2 discs yet because Im not sure what the thickness of these 2 will be (from the side view) and I haven't decided on a material either until I figure out how I would attach these 2 and still be able to twist the top one which is why I really need some ideas or help in figuring out a solution.
Any ideas for a mechanism to attach these 2 and be able to twist them would be greatly appreciated!
Sincerely,
Michael
Drilled/punched hole at the center and rivet together?
Possibly drill one and tap the other for a small shoulder / stripper bolt? Maybe add a small diameter nylon disc between the two to apply slight friction to hold in place? Maybe a top-hat style nylon bushing to provide both friction on the mating faces and a bearing for your "axle." Don't know if you want this to stay where you put it or if will be revolving etc.? Might want to take a look at the adjustment screws for a rifle scope if you'd like some alternate ideas on ways to "click" the disc to positive stop positions. V - shaped spring dropping into a knurled groove on the outer diameter. Or you could go with a ring of dimples on one face with a ball spring plunger to pop into the divots.
Good Luck!
Bob
1 Attachment(s)
How about 2 pieces of card and one of these:-
[ATTACH=CONFIG]745[/ATTACH]
Is there any brief on how far this needs to go in design terms?
Good luck.
Slam rivet
[IMG]http://www.engineersedge.com/engineering-forum/image/png;******,iVBORw0KGgoAAAANSUhEUgAAAFAAAAApCAIAAAAtXjnzAAALoklEQVRoge2ZW2wb1dbHzxMSQoJXEFIfQAgQBCQuBSRekBACRQUEQkp5QYoqSiMkJARt1YCqlqfyAKEloaUJTRzHcWzHl7Fjj+3xjOfiufkytidjj51JPLbrxHHsOBfqXBp7zsPWiVBPk5qecs7J953/g2XLM/b67b322v+95m/a/zP97T8dwL9b/wPeQ/Pz84VCAYIgo9EoCML29ramaa1W66+M7S/RnsC7MIVCged5k8mk0+mMRqNer+/r64NhWJZl7QAy7zfD29vbTqcTw7BUKjU/P1+pVCqVSqlUUhQFwzCz2cyyrHbQmPcDRlGUIIjNzc2VlRWapkmSpGkaw7BgMMgwTDQatVgsmUxGO1DMtwEG0QeDQZ/P12q1arUahmEoino8nuHhYRRFGYbhOE5VVYZhRkdHtQMNDEJfXV1FUbRYLCqKwvM8y7LJZLK/v9/hcKiqms1mFUWRJAnDML/fX6lUNE1rNpv/gfA1rdVqNZvNZrPZ5qDfHhjHcUmSIAjS6XQIgiQSCZPJhCDI77//Xq1WSZI0Go1DQ0MIgnAcF4lEms3mzs7Ovae5k+4is26T0mtra7lcDobhCxcuUBRltVo/+eQTURQ1Tdva2lpeXsYwDIKg3377rVAoSJIUDAbvQex3q3q9Ho/HGYZZWVlp5/rbAAuCIIri6Ojo1atXQ6EQQRCdnZ3Hjx/PZrOtVqterxMEQVFUMBhkWZYkycHBQbPZHI1GNzY27jXOflpfX6dpenR0lCAIu91uMplsNluj0dj/rluBd3Z24vE4iqKXL19GEMTtdtvtdkmSLl261N3d3dvba7PZSJJkGCaRSPA8L8typVKZnJy8cuUKhmF/FdwfBNI4n8+PjY2B8hkIBLxer8/ns9vtGIbduHFD2zvbbwVeWloSBCEWi9lsNlEUcRxnGEaW5WQymc1mbTZbb2/v559/fvr06V9//dXn8xUKhVOnTj355JNvv/328ePHwc68z//dEymKAsOwIAgIgjgcDqvV6na7/X4/z/N+v9/lcm1ubu51763AhULB7/cnEgkMw/L5POBUVZUkybm5OU3Tms1mPp/3eDwDAwPHjh179913n3jiiY6Ojtdff/3pp58+c+bMwsLC3QHf8RZwQbVaBZNBEITX63W73S6Xy+PxwDAcCARIkjSbzSDUtoDL5bLdbicIAsOwubm56elpVVWLxWImk6nVauvr641GY2trC1xMEMRzzz336quvvvHGGx9//PH777/f09OzOy5/FngvyN2BAG8ikQhN08AIBYPBQCCAIIjX6/X7/QiC0DRtMBhisVi7wDabDYIgh8Nht9uTySRJkpIkRaNRFEVLpdLm5ubW1tbGxkaj0djY2GBZ9pVXXnnqqafeeuutM2fOHD169KuvvgLe60/tUhsbG/F4HIIgDMNmZ2c3NjZu3rx5W3hFUViWZVkWRVGKojAMC4VCFEWh/xCO4yRJGgyGxcXFtoCvXbsGVoXRaEQQRK/XYxgWi8U4jpuZmSmXy7VabWlpqV6vNxoNq9X64osvvvTSSx988ME333zz4Ycffv3116qqam3MMJi6ZrOZy+UgCLLb7TiOoyg6Njb2008/6XQ6n88nimKxWKzVartrkmVZn88XjUZDoRCO47FYjOf53QlHEARBkEgk8ssvv8zMzLQFbLPZbDYbRVFmsxmCoJGRERRFp6enE4lEKpXKZrPZbDafz8/Ozlar1YGBgZdffvnNN9/86KOPTp48eeTIkYsXLy4tLe2P+keVSqVgMFgsFhcXF1VVlWU5lUqJohgKhZxOp9FonJiYmJqaIkkyFAp5vd7Jycl4PI5hGE3T4XDYarXq9XpBEMAQoCjq9XppmtbpdARBtAU8Pz9vMBgSiQQEQRAEOZ3O+D8kiqIkSZIkiaIoCEK5XB4YGHjttdeOHj3a3d3d09Pz/PPP4zjeDidYjVtbW+l0GmREo9FYXl5eWFjI5XKKosiyPDc3p6qqoiigPk1OTg4ODoLpJUkyHA4PDw+fO3dufHycpulsNsvzPI7jHo+HIAiTyWSxWNoCLhaLk5OTsiwjCGK32xEEkWU5k8lcv35dVdVUKiXLsizLLMvm83mLxfLYY48dOXKkq6urs7Pz/Pnz1WpVa6PegoQHHYW1tbWFhYV6vX7jxo3V1dW1tbWVlZVarVYul8vlcqlUyufzhUJBVdXJyUmGYSiKEkXRYrG8884758+fN5lMJEmCAQIJT1GU3W6fmJhoC3h1dZVhmGQyGQqFbDabx+OZnZ1VFOXKlSvnzp3r6+u7dOmS2Wx2OBwcx6Eo2tHR8fjjjz/77LM9PT1er/fOk/sHZbPZ/v7+TCbD8/z09HQqlUqn05lMplQqVavVSqWyurpaqVSWlpbW19ez2ezIyIgoihRFSZLU2dn56KOPfvbZZzqdThCEZDJZKpUSiQSCICRJOp3OsbGxtoA1TaMoCsdxWZadTqfP5+M4rqur69tvv2UYhud5r9frcrlcLpfX6/3hhx8GBwfPnj375ZdfwjC8z3Z/Wy0sLFy+fDmTyZAkieM4RVEEQRAEwTCMIAiJRCKdTiuKMjc3Vy6X/X4/BEFgubrd7oceeujQoUOffvrp6OhoKBSKRqO5XG5mZgbU7ampKZ1O1y5wOp0WBEFRlFAolM/nz549e/r06Z2dHVVVwZKbnZ0tl8tgXMLhME3TmUzmLjbeQqFgMBhUVU0mk5FIJBwOcxwXCoVCoVAgEMBxnCAIHMc5jpNl2Wg0+v1+mqZTqVRvb++DDz74yCOPdHd3g0MbRVGZTCafz4N65nQ6zWZzW8DgYDk1NSVJUj6fj0ajgUAgk8mwLCuKYjKZBN4rGAz6/f7V1dU/CwkEFnmr1RIEAcOwxcXFdDqdy+Xy+fzc3Jwsy4IghMPhcDgM6jPLssPDwxzHMQyTTqffe++9+++//9ChQ8eOHfvuu+8GBwfdbrckSZVKBcMwnucnJiYcDkdbwCCUWq3m9Xqnp6cVRZmdnU2lUjRNp9PpWCzGMAwMw263u1araZq2s7Ozs7PT/vn7lj+qVqswDHMcl81mwT5fr9fr9fri4mKxWAQOTxRFjuMGBwfj8ThN05FI5IUXXnjggQcOHz78xRdfnDp16uLFiyaTKRwOLyws4DgeiUSGhoaSyWRbwLuhLC8vezwelmXBzu73+91uN+jyMAwDluu/6B/B7cvLyy6Xy2Aw+P1+kiQFQRAEYWZmplgsViqVlZWVYrEYj8f1en00GgU2q6Oj47777jt8+PDJkycvXLhw9epVk8nE83wul/P5fDRN9/f372Wn92viNRoNCIJ4nkcQhCAIo9HI8/yukb63Wl9fT6fTgUDAYrHAMAyKLU3TMAzzPE8QhMViiUajDMOwLPvMM888/PDDXV1dfX19drvdarXabDbgjrxeL47jBoOhXC7/aeB/ztK7SN02BWwmWCC3fLW5uQnMfDweDwaD8Xj8xIkTJ06cMJlMsVhMkqREIhGPx69fv06SJEVRIyMje+Wz1uaTh39/U3KXH3wsl8sEQQCPJQjCwMDAzz//jKJoNBqVJCkSiWSz2Uwmg6IoSZIOhyOdTu/1y//tz5bAWK+srIDyS9M0y7Iej+f7778PBAI8z9vtdgiCcrkcSHiPx+NyufZpNv23A++KIIhIJMKyLCjU165d0+v1ZrP5xx9/ZBhGkiRQn8EhUdv7fHpggJ1OJ6jSFEWBVwiCCIJIpVKZTAbDMI7jOI4bGhpqNBr7bB8HABhkNcMwwWBQEATQjQEOlGXZaDQKDGkymZyYmLjj464DAAy0tbWl1+vD4TCwtDAMg4MRsJ+CIHi9XoPB8MeW0G11YIA1TRNF0e12g54WaG6AtrkgCH6/32Qy1ev1O/7IwQAG87a9vR2LxYLBIGiM0zQdi8WSyaTb7R4fHwdW94476MEABmq1Wjdv3uR5fmhoaHx8HIZhq9Xa39+PIAhovrdjdQ8S8D3R/4D/r+vv0VlNHjwUgdUAAAAASUVORK5CYII=[/IMG]
[url]http://www.mcmaster.com/#slam-rivets/=p82ge3[/url]
