1 Attachment(s)
deviation in perpendicular direction of the ram
Hi to everyone,
I have a strange problem with my machining center. I have a horizontal bed type machining centre (traveling column), and I’ve noticed an error when I move the ram.
I move the ram to the outer position (up to the final of the course), and the tool tip goes straight, but when I reverse the direction and I start moving inside the ram, the tool tip has a displacement in the X direction (the direction of the bed), and the tool tip goes inside in an inclined straight line. In the picture below you can see the trajectory that my tool tip follows.
[ATTACH=CONFIG]275[/ATTACH]
The machine tool has a direct drive with a rotary shaft in the ram, and a fixed nut in the carriage. I don’t know if it is an error of guides, a drive problem, if it is because of any existing clearance …
As I think that you have more experience with machine tools than I do, I would like to know whether any of you has noticed any similar problem with any machine tool, and if this is the case, which problem you detected and how did you solve this problem.
Thanks in advance,
Best regards,
