ID change due to heating on a press fit polymer bearing
I am in he process of writing a design calculator and would like some insight regarding the following:
Assembly: Polymer bearing press fit into a steel sleeve
For numbers sake:
Sleeve: 410SS (avg CTE of 5.7E-6 /°F)
Size: Ø10" x Ø9" x 6"
Polymer Bearing: Carbon filled PEEK (avg CTE of 24E-6 /°F)
Size: Ø9.013" x Ø8.5" x 6" (.013" interference fit, Ø8.5" must be cut for clearance to shaft)
Shaft: Ø8.5"; 410SS
Temperature range: 75°F to 275°F
Desired diametrical clearance at 275°F: .010" minimum
I am looking for a method to calculate the change in ID due to the temperature increase and the restriction of free growth. So far I have worked to the following:
ID=Shaft diameter + Clearance + Shaft Expansion + 2*Bearing Cross-section (Cx) Expansion + Differential Expansion of Bore to Bearing OD
Differential Expansion of Bore to Bearing: Bearing OD Expansion - Bore ID Expansion
The 2 parts that I am not comfortable with are the Bearing Cx and the differential expansion. Is this double dipping in the amount of expansion/contraction that the bearing will see? There is a certain amount of expansion that the Cx will see, but yet there is also thermal growth that is now restricted due to the interference fit and the difference in CTE's.
Thank you for any and all input/assistance
Richard
