Removing inside weld line of a pipe
What is the best and fastest way to remove the inside weld line of pipes with 16mm outside diameter and 1m thickness so a piston can reciprocate easily inside it? I have two options in mind. one is to have the inside of LSAW pipes machined, which might be laborious. The other option is to cold draw ERW pipes (I think cold drawing LSAW pipes would not result in smooth and accurate enough inside surface). I'm not sure whether either of these methods works. Is there a better way to to this? The end product is 12cm Cylinders which will be produced at least 1000 in quantity per day.
