4 Attachment(s)
Need help with project. Type of machines that should be used to produce such shape.
Hi guys...i really need ur help ..what types of machining process should be used to produce such shapes ?
[ATTACH=CONFIG]1010[/ATTACH][ATTACH=CONFIG]1011[/ATTACH][ATTACH=CONFIG]1012[/ATTACH][ATTACH=CONFIG]1013[/ATTACH]
Fulcrum Handler Fulcrum Upper pin
For the fulcrum and the upper pin i think it would be easy by using the metal injection moulding process or maybe sheet-metal stamping, but the problem is that in my university theres no way I can use such machines. So i'm going to find an alternative way to produce such shapes maybe by using some much more 'simpler' machine.
I've been 'googling', searching some on youtube, refer to manufacturing books and it seems like the there are 2 types of machining process that maybe can produce such shapes. it's probably milling and lathe machine.
What is ur opinion guys ? is milling and lathe machining able to produce the shape above ? if no, is there any alternative ways to produce such shapes ?
Need ur help guys. I really had no experience in machining. Last year, we got a chance to use some machines that is used in manufacturing(lathe, milling, drilling,etc) , unfortunately we only used the machines 1 times for 1 machine. I think, one time is not enough to truly understand how the machine works. I really hope anyone can give a suggestion of how to produce such shapes. Thank you.
Regards from Malaysia,
Jabri.
