2 Attachment(s)
ISO standard GPS and dimension tolerances and iso 8015 standard
Hello to you all, I am new to this forum.
I try to find experts for the ISO drawing standard, I hope I am in the right place.
Here are a few questions :
1. First I would like to know, if I put a dimension, let say a diameter of a cylinder with a tol. of 0/-0.2. does it means that the straightness of cylinder must be 0.2 or lower? or must I state the Geometrical relation along side with the tolerance, what does not make real sense.And In which Std. does this roles stated?
2. If I understand the Iso 8015 correctly, It means, if stated in the drawing title block, that the dimension's tol. do not apply for the geometric relation (as in the previous question) , hence the "Principle of independency" apply. If so, I could write diameter tol. of 0/-0.2 and straightness of 1. If what I wrote is correct than how do I measure the dimension of the cylinder?
Please refer to the following drawing:
As shown on drawing, with the ISO 8015 stated:
[IMG]http://www.engineersedge.com/engineering-forum/attachment.php?attachmentid=1974&stc=1[/IMG]
How to measure?, the following drawing shows the measured dimension, is it correct? what "max" dimension will still comply with the upper drawing?
[IMG]http://www.engineersedge.com/engineering-forum/attachment.php?attachmentid=1975&stc=1[/IMG]
I hope I have explained my self clearly ,
Thanks
