Sch160 2 1/2 pipe process/material for application
I am looking for the correct pipe term and having a bit of trouble.
It is sch 160 2 1/2 pipe
OD 2.875
ID 2.125
2" in length
Within the pipe is a
2" cylinder diameter by .2"
Central exhaust to ATM
The pipe will experience a constant regulated external temperature of between 300 and 315 degrees Celsius(570-600F) . This temperature is supplied via voltage. When the voltage is shut off the cylinder will experience external temperatures between -24 and 32C(-10to90F).
4800 psi of compressed vapor(NOT STEAM) will be injected into the pipe for short mechanical "pulse" duration of .15 to .20" of the stroke, with [U]no vapor expansion[/U], forcing a 2"x.2' cylinder to move .875" before a central exhaust port is exposed.
I should be well within the pipes limitations with the short duration and stroke of the cylinder. The gap around the cylinder and short duration should lessen the pressures further. But, I want to make sure I have the correct terminology when ordering the pipe so I am supplied with the correct material.
The list in the below link shows seamless(a106) and welded(a53), a333/334, as well as the varying grades and other classes to add to the fun of a hobbyist such as myself.
I need to make sure I am dealing with the correct material without ordering specialized and more costly material then I need.
Thank you for your time and help.
