Standard face to face tolerances on welded components.
I'm looking for the end to end acceptable tolerance for welded components. We manufacture valves here and we are getting the flanges (2" 600 sch80 in this specific case) welded to the end connections for the valve. The best answer I can find is in ASME B16.10 section 5.1 (straightway valves) where they list a tolerance of "+/- 0.06in shall be allowed on face-to-face and end-to-end dimensions of valves NPS10 and smaller". My issue the valves it seems to show in this spec look like fully casted valves so i was wondering if there is a different spec for welded end connection valves or components.
We are trying a new welding shop and are getting push back on the tolerance i've listed on the weld drawing of +/- 0.03" for the face to face of the end connection (2 ends at 0.03 each gives 0.06). They are telling me that they weld pipe all the time and are used to 1/8" tolerances. Any help would be greatly appreciated.
I've been pointed to pipe world which seems to answer every other question except where they reference the "Tolerance on Linear Dimensions".
