Anybody know the formula to calculate the steel weight?
Printable View
Volume x lbs/volume
+1 kelly
.283 lbs/cubic inch
Hello there
If you steel shape is simple their answers are right but are your shape is not as a geometric shape I suggest you model it in SolidWorks software and go to the evaluate and find its weight with a high accuracy
First calculate the volume of the steel sheet. Note: If you are calculating the weight of circular steel reinforcement bar than calculate its volume by using this formula (πD^2/4) and then just multiply by the density of steel which is 7850 kg/m^3 and you will get the final weight of the steel.
Calculate Weight of Steel Bars
1. Estimation of Steel Reinforcement for slab,beam and column.
2. Weight of steel Flat bar = (Length x width x thickness) x 7850.
3. Example 1: Determine the unit weight of MS Flat bar of width 40mm and Thickness of 20mm.
4. Weight of steel bar = Volume of steel Bar x Density of steel.
[LIST][*][FONT=arial]Weight of bar in kg/meter should be calculated as (d[SUP]2 [/SUP]÷ 162) where‘d’ is the diameter of bar in mm.[/FONT][*][FONT=arial]‘L’ for column main steel in footing should be considered as minimum 30cm/as specified.[/FONT][*][FONT=arial]For bent up bar add 0.42d in straight length of bar where‘d’ is the clear depth of beam/slab.[/FONT][*][FONT=arial]For cantilever, beam anchorage length for main steel should be 69D or length of cantilever whichever is greater.[/FONT][/LIST]
[h=4][FONT=arial]Weight per meter of different dia of steel bar.[/FONT][/h]
[LIST][*][FONT=arial]6 = 0.222 kg per meter[/FONT][*][FONT=arial]8 = 0.395 kg per meter[/FONT][*][FONT=arial]10 = 0.617 kg per meter[/FONT][*][FONT=arial]12 = 0.888 kg per meter[/FONT][*][FONT=arial]16 = 1.58 kg per meter[/FONT][*][FONT=arial]20 = 2.469 kg per meter[/FONT][/LIST]
[COLOR=#000000][FONT="][FONT=arial]With help of this formula you can find any type of dia bar weight[/FONT][/FONT][/COLOR]
[COLOR=#000000][FONT="][FONT=arial](d[SUP]2 [/SUP]÷ 162)[/FONT][/FONT][/COLOR]
[COLOR=#000000][FONT="][FONT=arial]Where[/FONT][/FONT][/COLOR]
[COLOR=#000000][FONT="][FONT=arial]D = diameter of bar in mm.[/FONT][/FONT][/COLOR]
Weight is a measure of the force of gravity pulling down on an object. It depends on the object's mass and the acceleration due to gravity, which is 9.8 m/s2 on Earth. The formula for calculating weight is F = m × 9.8 m/s2, where F is the object's weight in Newtons (N) and m is the object's mass in kilograms.
