1 Attachment(s)
Plain Bearing for 2 Inch Pole Question
I'm making a custom monitor articulated arm using 1.5" and 2" posts (Pipe). I don't know the mane or where to buy (US) of the in-line revolving connector (Pin and Bushings) required for vertical linkage. It resembles te type foud in lift-off metal hinges, like the bullet tpe. But essentially what I'm trying is to use the pipe sections adding only internal nylon bushing and pins with little tolerance to prevent wobbling. If you know a place to buy online in kit form, it would help me lots!. But essentialy, I need the correct connector name to find it.
Here is an image of what I want to do. If you know any other/better arrangement, welcome!
Thx in advance
MM
